Date/Time: Fri, 07 Mar 2025 01:13:11 +0000
new update issue
View Count: 442
[2022-02-23 15:11:41] |
blackcobra777 - Posts: 28 |
hye i want to tell you after i update to new version 2357 my sierra chart setting change i want to set auto matically chartbook from global setting to general setting but when go to global and general setting there is change this opens now i attached the file where is the older one where we set chartbooks open when we open sierra chart https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=61679 |
[2022-02-23 15:46:55] |
To set the Chartbooks to open on startup go to Global Settings >> General Settings >> General 1. Scroll down to the Startup section and then and then left click twice where it says [Select Files to Open on Startup] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
