Date/Time: Fri, 07 Mar 2025 01:10:57 +0000
Number bars
View Count: 511
[2022-02-23 15:10:15] |
mrcfc - Posts: 2 |
Hi, i have a problem with number bars study. When i add it to my chart (happens with any symbol) the canddlesticks, bars etc dissapear. With volume profile and other studies doenst happen. Thank you for your help!
[2022-02-23 18:52:19] |
John - SC Support - Posts: 38467 |
This is correct functioning. Refer to the following for how to put on Open to Close boxes to the side of the Numbers Bars: Numbers Bars: Drawing Open to Close Boxes on Side of Numbers Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
