Date/Time: Sat, 26 Sep 2026 05:39:11 +0000
Spotgamma levels CPU issue
View Count: 1348
| [2022-02-23 09:57:54] |
| User274507 - Posts: 37 |
Hi, I use spotgamma levels link, it's been working fine but after I updated Sierra chart it is now saying CPU exception caused and not showing the levels, any idea of what I should do? thanks, Nick |
| [2022-02-23 18:28:53] |
| John - SC Support - Posts: 48028 |
You need to talk to the developer of that study and let them know.
| [2022-02-23 22:24:19] |
| Borubar - Posts: 17 |
They changed links today.
| [2022-02-28 17:34:37] |
Also refer to this help topic: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
