Date/Time: Fri, 07 Mar 2025 01:07:18 +0000
Do I have this Multi Connection DTS Set Up Correct?
View Count: 529
[2022-02-23 08:13:51] |
User429065 - Posts: 128 |
Can you please confirm my DTS settings here are correct? Everything seems to be working properly, I just want to be sure the SC Denali data feeds are being applied. 1) I am trading with Apex login credentials as a proprietary trader using 2) Denali login credentials for all my historical and market depth data. 3) I then switch over from Apex to my $150+ funded broker login credentials (assigned to "Trading Username" / "Trading User Password") once a month to avoid the higher cost charges for professional traders, correct? Thank you for your confirmation!
Date Time Of Last Edit: 2022-02-23 08:55:40
[2022-02-23 18:21:07] |
John - SC Support - Posts: 38467 |
For the "Market Data" and "Historical Data" on the Data/Trade Service Settings, you would want to enter your Rithmic account name. It really does not matter, given that you are setup to get the data from us, but still, it is the "more correct" entry since that is what it would be checking for.
