Date/Time: Fri, 07 Mar 2025 01:20:57 +0000
installation trouble
View Count: 452
[2022-02-23 02:05:44]
User369920 - Posts: 2
my client is not installing i am trying to use it on a computer with a firewall which is likely the problem. It is not receiving the files to install. Is it possible to install it on a pc through an external hard drive?
thanks.
[2022-02-23 02:33:05]
Yes you can just simply copy the files. You can use the ZIP installer:
Software Download: Sierra Chart Zip Installer
