Date/Time: Sun, 09 Mar 2025 01:39:28 +0000
Removing old brokers account and sim account from trading DOM
View Count: 602
[2022-02-23 02:05:10]
eminimom - Posts: 24
Hello, I was a Transact user and converted to Stage5. The old brokers account and related SIM are in the rolldown menu on the Trade DOM Window. How do I remove that from the DOM since there are two SIM1, one for the Old broker and one for the new broker. Thanks
[2022-02-23 23:24:54]
Sierra_Chart Engineering - Posts: 18694
We do not see how this is technically possible. Provide us a screenshot of what you are seeing. Instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage
You can privately attach it.
[2022-02-24 20:19:13]
This is a second instance, it shows two SIM1 in list. See file attached.
Private File
[2022-02-24 21:10:53]
We do not have an explanation for this and cannot reproduce.
Just disregard for now.
[2022-02-24 21:11:58]
Ok actually we can reproduce. Just disregard this. It does not cause any harm. We will look into a solution later on.
