Date/Time: Tue, 26 Nov 2024 06:50:00 +0000
Assistance with delta volume per bar programming
View Count: 1773
[2014-04-16 15:43:42]
User12676 - Posts: 70
Dear SC,
For the delta volume per bar chart I would like to program an indicator with histogram that will increase every time there is a change in control (more buying/more selling) in the bar before it comes finalized. Could you point me in the right direction to get started?
Thanks,
Mike
[2014-04-16 18:05:59]
We can only refer you to the documentation here:
https://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html
We do not provide programming help.
[2014-04-16 18:18:57]
Ok thats fine. I know where stuff is on your site. I have programmed several indicators already. Your reply gives me no head start in any direction. I mean c'mon you guys know best where I can get started, give me a pointer. I dont know if I can access the volume diff ber bar chart source code.
[2014-04-16 18:19:23]
Since it is not a study..... its not in the study source code
[2014-04-16 18:35:48]
Zosimus - Posts: 345
I am not a professional programmer either but I may be able to help you if you help me understand better what exactly you want. But before I try to help you please start this thread again as a [User Discussion] so that the SC team will not have to spend their time on this.
[2014-04-16 18:43:01]
You do have access to the bid volume and ask volume chart arrays which are used by the Delta Volume bars:
https://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scBaseDataIn
