Date/Time: Fri, 07 Mar 2025 01:19:10 +0000
[User Discussion] - Heiken Ashi Diff
View Count: 872
[2022-02-22 21:49:59]
User97303 - Posts: 16
Can someone show me the formula for this. It is the Heikin Ashi diff indicator from TOS.
Thank You
image2022-02-22_16h41_35.png / V - Attached On 2022-02-22 21:47:47 UTC - Size: 118.85 KB - 195 views
image2022-02-22_16h41_52.png / V - Attached On 2022-02-22 21:48:46 UTC - Size: 35.36 KB - 175 views
[2022-02-22 23:42:19]
We do not understand the question because this is not about Sierra Chart.
[2022-02-23 00:39:01]
Sawtooth - Posts: 4181
Using four native studies, you can create the Heikin Ashi Diff indicator:
Try this:
1. Add the Heikin Ashi study, check Hide Study.
2. Add the Study Subgraphs Subtract/Difference study.
- Enter 'HADiff' in the Short Name field.
- Set the Input Study 1 to <Main Price Graph>, Last (SG4).
- Set the Input Study 2 to the HA study, Last (SG4).
3. Add the Line study.
- Set the Chart Region to the same as the Study Subgraphs Subtract/Difference study.
- Set the 'Value' to 0.
4. Add the Moving Average - Simple study.
- Set the Based On to the Study Subgraphs Subtract/Difference study.
- Set the Input Data to Diff.
- Set the Length to 2.
- Note: You may need to adjust the Length to match TOS.
