Date/Time: Fri, 07 Mar 2025 00:56:24 +0000
Trade Activity Log Time-stamping confusion
View Count: 501
[2022-02-22 21:01:17] |
User414533 - Posts: 106 |
This change you guys made is really making things hard on me. To organize market replay dates/results I have to remember the actual day I traded the replay on instead of the replayed date (which is by FAR the most intuitive organization method). I'm totally lost looking for a solution. All I can think of at this point is making a separate demo account for every segment of testing that I want to be able to easily display together. Do you have any other ideas? Maybe just change it back to the way it was? :*( |
[2022-02-23 01:26:59] |
Yes we understand. We do see the consequence of the change regarding back testing. So we probably will revert this back and come up with some other solution.
