Date/Time: Fri, 07 Mar 2025 01:28:38 +0000
Installed Bookmap and now SC doesnt work
View Count: 589
[2022-02-22 18:22:04] |
User708382 - Posts: 3 |
Ive installed Bookmap on my trading computer and now SC hangs up so much it doesnt work anymore. My computer has 16GB of Ram which should be enough for both these programs. Any ideas to fix this issue?? Thanks |
[2022-02-22 19:50:51] |
One thing we would recommend is installing Sierra Chart on its own dedicated solid-state drive: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.29 - Solid State Drives / SSD Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
