Date/Time: Fri, 07 Mar 2025 00:58:05 +0000
Chart Windows Z-index?
View Count: 580
[2022-02-22 18:19:18]
User189590 - Posts: 3
Is there anyway to have a chart appear above all other windows, regardless which one is focused? Say I wanted a small chart in the top left floating above my other charts.
I tried the "Window Always Visible" but that doesn't seem to do that.
Thanks,
[2022-02-23 17:15:05]
John - SC Support - Posts: 38467
You need to detach the window and then use the option Window >> Always on Top. Refer to the following:
Window, CB and CW Menus: Always on Top (Window)
If you use multiple chartbooks and want to have that window visible regardless of which chartbook is open, then you also want to enable the option for Window >> Window Always Visible. Refer to the following:
Window, CB and CW Menus: Window Always Visible (Window)
