Date/Time: Fri, 07 Mar 2025 01:13:32 +0000
Swing trading with attached orders and trade management by study
View Count: 514
[2022-02-22 16:45:05]
traderacefly - Posts: 57
I use attached orders STOP/TARGET with my entries. When holding a position past the close, those attached orders are stripped away. After the market reopens, I'll manually add a buy/sell STOP but then the Trade Management by Study does not recognize these orders. I get the following message...
"The found Stop/Target order is not in an Open/Held state."
Two questions:
1) Why are working orders removed after market close? Can this behavior be modified?
2) Is there a way to re-add my bracket order after market reopen that is respected by the Trade Management by Study?
[2022-02-22 17:13:49]
1. Make sure they are set to Good Till Canceled:
Attached Orders: Time In Force
2. Refer to:
Order Types: Send Attached Orders - Position/Price
[2022-02-22 19:44:31]
Thanks for the quick reply. #1 TIF I changed from Day to Good till Cancelled. #2 I had to add "Send Attached Orders by Price/Position" to the chart trade menu in order to send a bracket order for a live order. However, this did not solve the issue with the Trade Management by Study working with this new bracket order.
I tested this by cancelling the existing working orders for a live order entered with an attached order. I then manually used Send Attached Orders by Price, which worked, but now I'm getting a slightly different message in the message log (see below). And it is not trailing my stop like it does if it was a "natively" initiated attached order.
Chart: ESH22_FUT_CME/MESH22_FUT_CME[M] Flex Renko 5-4-0 #8 | Study: TRAILING STOP | There is no Stop/Target Attached Order found. | 2022-02-22 13:38:20.919
Attached is the Trade Management by Study config screenshot.
Date Time Of Last Edit: 2022-02-22 19:46:26
image2022-02-22_13-41-41.png / V - Attached On 2022-02-22 19:43:54 UTC - Size: 92.27 KB - 140 views
[2022-02-22 20:39:31]
Update: I figured it out. I set the Trade Management by Study "Attached Order to Manage" from OCO Group 1 to Nearest and then it started to work.
[2022-02-23 01:28:09]
Ok good.
