Date/Time: Fri, 07 Mar 2025 00:53:03 +0000
Delayed Data
View Count: 436
[2022-02-22 15:09:34] |
Michael_pounds - Posts: 3 |
Hi- Could you tell me why my data is delayed by 10:10? Thank you.
[2022-02-22 17:01:22] |
If you are looking for real-time data from the CME group of exchanges, then you need to activate the exchanges that you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
