Date/Time: Fri, 18 Sep 2026 11:50:36 +0000
Keep getting
View Count: 684
| [2022-02-22 15:09:11] |
| User355317 - Posts: 12 |
HI. I'm trying to connect to the denali data feed but it's not letting me. I using Amp futures as my portal. And my name and password are in the sierra chart app correctly. Can you please help me connect so that i can start trading live? Thanks.
| [2022-02-22 16:31:55] |
You are not currently using the Denali Exchange Data Feed. To use it follow through the instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
