Date/Time: Fri, 07 Mar 2025 01:25:44 +0000
TransAct support ending
View Count: 633
[2022-02-22 15:06:43] |
User41683 - Posts: 37 |
TransAct support from SC is ending. However I don't trade via SC. I use their DOM. I use your Denali data for the charts on SC but I have to log in once a month for the non-professional status. How am I going to do this after June this year? Regards, Sam |
[2022-02-22 16:41:52] |
First, please consider using the Sierra Chart Trading DOM which is very good: Chart Trading and the Chart DOM: Trade DOM And if you look at brokers supporting Teton order routing, you may find that you get better commission rates. Teton order routing: Sierra Chart Teton Futures Order Routing You should also consider, that Teton order routing gives you server-side OCO and bracket orders. We are fairly sure that this is something that the Transact DOM does not support. It has not supported this in the past and if it has not been added, it is not supported. This is very very important, especially being you are in Europe. Regarding the original question, we have developed a solution for this: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-22 16:49:53
[2022-02-22 16:48:42] |
Stage 5 Trading - Posts: 155 |
As a former Infinity Broker I fully understand the trials and tribulations of changing brokerage firms and no longer being able to use the Transact AT DOM. With that being said, Stage 5 takes great pride in helping Transact/Infinity traders transition as seamlessly as possible. Personally, I believe the best solution would be to switch to Sierra Teton Order Routing with Denali for real time and historical data and trade through the Sierra DOM. This is all maintained by Sierra directly, which I feel provides great benefits to traders as Sierra can focus on enhancements instead of maintenance of other third party order routing feeds. In addition, I feel it is the best overall quality and value for traders. If you decide to open an account with Stage 5 Trading, you will receive $0.20 per side commissions on the micros and $0.45 commissions on non micros plus exchange and regulatory fees. Please feel free to contact us and we will gladly assist you with any questions you may have and/or the process of transitioning your account and hopefully helping you improve your current trading solution. We would be able to provide some DOM chartbook layouts that will hopefully be more in line with what you are accustomed to. In addition, we would be more than happy to have a remote session to help get you setup with the new layouts. If you have questions or would like to speak to an assigned personal broker for details, please call us at 1-312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/ If you are ready to move to the Teton Order Routing solution right away, we invite you to complete an application by clicking the blue button at the top of the https://stage5trading.com/ page that says "Introducing Sierra Chart Teton Order Routing - Click Here to Open an account" Please let us know if you have any questions or we can assist with anything along the way. Thank you, Anthony Giacomin Stage 5 Trading Corp. Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results. |
