Date/Time: Fri, 07 Mar 2025 01:02:26 +0000
Trade and Current Quote Symbol in Chart Settings
View Count: 1236
[2022-02-22 13:32:15] |
User94606 - Posts: 327 |
Can you explain how the Trade and Current Quote Symbol (see attachment) works under Chart Settings? The attached chart is for NQ and the Trade and Current Quote Symbol is set at MNQ
![]() Attachment Deleted. |
[2022-02-22 13:55:20] |
User431178 - Posts: 609 |
It is explained here - Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
[2022-02-22 17:06:07] |
Yes that is the correct link given at post #2.
