Date/Time: Fri, 07 Mar 2025 01:14:49 +0000
Flat to flat Max open profit/loss are incorrect in trade log
View Count: 1001
[2022-02-22 00:38:01] |
User809555 - Posts: 11 |
Hello there, today's stats in these categories are wrong in the log file. I will attach it. Basically "flat to flat open loss" is 0 for winning trades. While for losing trades "flat to flat open profit" is 0. I will attach the chart image where you can see clearly that my 1st trade(arrow) took for sure some heat before going to take profit target. https://www.sierrachart.com/image.php?Image=1645489631925.png Date Time Of Last Edit: 2022-02-22 11:02:18
Private File |
[2022-02-22 01:52:40] |
Sierra_Chart Engineering - Posts: 18672 |
Make sure there are no missing order fills and you have the correct Start Date-Time: Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List Trade Activity Log: Missing Order Fills from Trade Activity Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-22 11:01:26] |
It seems to me that there are no missing fills: I count 14 fills which matches with the 7 round turn trades I made. Start date-time is ok to me. Not sure what to do because this is the 1st time this happened to me. Another detail I didn't mention is that yesterday I traded with the 2348 version of Sierra Chart. |
[2022-02-22 16:43:08] |
Read the descriptions for these fields: Trade Activity Log: Trades Fields Descriptions They must be correct based upon the fill data, and the high and low prices during position. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-22 16:44:59
