Date/Time: Mon, 28 Sep 2026 06:15:25 +0000
[Programming Help] - Input length 128 not working
View Count: 862
[2022-02-21 15:55:31]
User301688 - Posts: 3
Hi Sierra,
I can see in the documentation that the maximum input length is 128.
ACSIL Interface Members - sc.Input Array: Introduction
Unfortunately, my max input length is 64.
How can I increase it?
Thank you
[2022-02-21 17:43:41]
John - SC Support - Posts: 48028
The 128 is the number of inputs, not the length.
If you are having issues with the length available, then you can always use multiple inputs for what you need, or you can use String input type and parse the string if that is easier. Refer to the following:
ACSIL Interface Members - sc.Input Array: sc.Input[].SetString()
