Date/Time: Fri, 07 Mar 2025 01:04:46 +0000
Trading through spreadsheet enabling
View Count: 484
[2022-02-21 15:18:48] |
Fabio - Posts: 121 |
Good morning, I use the "spreadsheet for trading studies" in order to execute my trades. With recent volatility, I find myself in need to use micro to manage my risk effectively. I have a question in regards to the --> Chart setting--> Main settings--> "Trade and Current quote symbol" Let's say that I have ES as the main symbol and MES as Trade and Current quote symbol. The spreadsheet where I execute trades is in the ES chart studies, (also indicated in cell J40 of the spreadsheet) Is there a way to be able to execute trades based on the symbol located in the "Trade and Current quote symbol" box while is being used? I hope I've been clear enough in my explanation... Thanks for your help! Fabio |
[2022-02-21 17:00:18] |
John - SC Support - Posts: 38467 |
As long as the associated chart has the Trade and Current Quote Symbol entered, then the orders will be for the symbol in the Trade and Current Quote Symbol. It's easy enough to test this, just use your Spreadsheet in Simulation mode and check your Trade Activity Log to verify the traded symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
