Date/Time: Tue, 26 Nov 2024 22:22:19 +0000
Zooming in/out could work like on common photo and / or PDF view
View Count: 620
[2022-02-21 15:05:55] |
User215639 - Posts: 17 |
... not only vertically and / or horizontally. Want to zoom both vertical and horizontal simutaneously around the mouse pointer 360 degrees around the pointer area. Doable?
[2022-02-21 16:39:04] |
John - SC Support - Posts: 36309 |
This has been set as a Feature Request.
[2022-02-22 08:47:47] |
Any time schedule for realizing the feature?
[2022-02-23 15:27:21] |
We do not know when or if, we will get to this feature. We are just marking it as something that we recognize people would like to have.
[2022-03-09 09:34:11] |
any positive progress about the issue for dev / bring into charts?
[2023-10-16 11:39:56] |
User408639 - Posts: 69 |
Moin Moin. A nice amendment-idea for Your upcoming feature.: Maybe it can be done by using a control-key-combination, and zooming in around the current mouse's position (Tradingview does it using the ctrl-wouse-wheel--combination). It would be helping to avoid loosing the current position (, e.g., the profile-block in TPO-graphs), if the mouse-wheel-zoom could be staying centered around, where the mouse/current-profile was=is. _Cheers, __Michael. P.S.: 1. Heeding Your first bullet-point's instruction, I did ask ChatGPT and found "Zoom in"/Alt-Z, so I do have a good workaround. 2. So, please put this suggestion to a low priority. |
