Date/Time: Fri, 07 Mar 2025 00:57:52 +0000
Horizontal scroll bar
View Count: 840
[2022-02-21 13:02:02]
User338291 - Posts: 2
Hi All,
New to Sierra Charts, and I'm sure what I'm looking for is simple, I'm just missing it!
So I opened an Intraday Chart, then in the same worksheet added 'Open Trading DOM for Chart'. Ok all good...
Going through some tutorials, I've added more columns using Customize Chart/Trade DOM Columns. Ok all good..
The prob is I can't see all the columns, and expected some kind of horizontal scroll bar, for ease of navigation.
The obvious choice Chart - Show Scrollbar ....umm it's greyed out ??
As I said I'm sure it's just something stupid I am doing!
thanks in advance..
[2022-02-21 16:30:07]
John - SC Support - Posts: 38467
On the Trading DOM you would have to change the size of the window by grabbing an edge and pulling (standard Windows resize). There is not a horizontal scrollbar option for this window.
[2022-02-21 16:52:13]
Oh ok John.. thanks.. any reason why not ? Seems like it would be a useful feature...
