Date/Time: Fri, 07 Mar 2025 00:51:00 +0000
NASDAQ Total View Intraday Volume Data Incorrect
View Count: 805
[2022-02-21 07:58:36] |
fykemang - Posts: 49 |
Hi, The NASDAQ Total View data works well for historical charts, but I do not see correct volume data for intraday charts. I like to use intraday daily charts, and the lack of volume is extremely noticeable. This causes the volume for intraday daily charts to be unusable. https://www.sierrachart.com/image.php?Image=1645430092511.png |
[2022-02-21 16:58:55] |
That is the correct volume from NASDAQ. It is only the volume for trading activity on NASDAQ.
[2022-02-21 17:18:03] |
Is there something in the works to be able to see more than just Nasdaq intraday volume?
[2022-02-21 17:21:42] |
Zptrader - Posts: 28 |
hello, do you think that you will be able to complete this data source to offer the complete volume of the session?. Thank you
Date Time Of Last Edit: 2022-02-21 17:22:21
[2022-02-21 17:41:49] |
We are looking into a more complete source for Intraday volume data for US stocks but we do not know when that would be available.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-21 17:42:08
