Date/Time: Fri, 07 Mar 2025 01:06:36 +0000
Questions
View Count: 480
[2022-02-20 19:02:53] |
User334486 - Posts: 7 |
Perfect thank you, I have 3 simple questions. If You could please reply that would be amazing. 1.) Does my data package handle, footprint/orderflow chart? If not, what is the next best upgrade for me? 2.) I can't seem to get drawings to sync to charts that are on the same link. 3.) What is the best package for live data regarding equities |
[2022-02-21 15:22:28] |
John - SC Support - Posts: 38467 |
1) You need to be on the Sierra Chart Advanced Package to be able to use the Numbers Bars (Footprints). Since you are using the Denali Exchange Data Feed, this means you would need to change to Package 11. Refer to the following quoted information for how to change your package: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. 2) Drawings are not handled through linking charts. Refer to the following for how to copy drawings from one chart to another: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) 3) For U.S. Equities we recommend using our NASDAQ TotalView data. Refer to the Setup Instructions here: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
