Date/Time: Fri, 07 Mar 2025 01:12:45 +0000
Display intraday data in daily and weekly views
View Count: 568
[2022-02-20 18:48:11] |
User755385 - Posts: 2 |
In the past, I would see the daily intraday data for stocks for the current day on my daily and weekly charts, but a month or two ago this stopped and I can only see the current day's data after the markets have closed. I normally look at stocks on the nasdaq. I have updated to the latest release to make sure this was not an issue with the version of the software I have. I have the normal historical data package and the intraday data seems to be downloaded during the day (with of course the 20 minute delay), because I see it when I open intraday charts, but when I switch to the daily or weekly chart, I only see data up until the previous day. I would like to get back to having the current day intraday data shown on the daily and weekly charts. How do I get this capability back?
[2022-02-20 19:00:32] |
Use the new NASDAQ TotalView data feed to receive streaming delayed updates: How to Use New NASDAQ Total View Data Feed | Post: 293421 Make sure you are using the right symbols. They end with -NQTV Make sure you are running the current version. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-20 19:01:24
