Date/Time: Fri, 07 Mar 2025 01:12:58 +0000
The difference between the volume of the historical graph and the intraday graph
View Count: 701
[2022-02-20 10:16:54] |
User485486 - Posts: 43 |
Hi, What is the difference between the data of the volume in the historical graph and the intraday graph? In other words, when I open a daily graph in intra-day graph data the total number of the volume differs from the total number of the volume in a historical daily graph, why does this happen? Thank you |
[2022-02-20 10:42:11] |
Refer to: Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts (How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-20 10:42:23
[2022-02-20 11:18:57] |
Sorry, I meant the vertical volume not the horizontal volume, I could not find there information on this topic ... Did I miss it in the link you attached?
[2022-02-20 11:25:25] |
We do not understand what you mean by vertical volume. In any case, refer to the section titled "How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts) " in the link in our prior post.
[2022-02-20 14:59:57] |
Sorry, when I write vertical volume I mean the normal volume that is below the price action. The numbers that appear in a historical graph are different from those that appear in an intraday graph. I did not find a reference to it in the link you sent, did I miss something there?
[2022-02-20 15:13:54] |
Refer to: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-20 15:14:10
