Date/Time: Fri, 07 Mar 2025 00:57:15 +0000
Nasdaq total view feed data
View Count: 732
[2022-02-19 15:44:27] |
Zptrader - Posts: 28 |
hello, any news on the solution for the nasdaq total view data feed to show the total volume data. As long as it is not requested, that data is not useful.
[2022-02-19 17:04:29] |
No there is no update in regards to this. This is the data that NASDAQ provides and it is correct.
[2022-02-19 20:41:21] |
Hello, sorry I didn't express myself correctly. I meant if this "We are going to be adding a new full consolidated tape data feed for US equities data. This will provide the full volume data. It is our intention to combine that data with the market depth data and market by order data from the NASDAQ TotalView data feed, into a single data feed." It is planned to do so in the short term. It is a necessary action from my point of view to improve the usefulness.thank you for your reply. |
[2022-02-19 20:52:15] |
We need to put out some information about that. The information we received from NASDAQ regarding this particular data feed was misleading and this is not going to be the case. At least not exactly like we thought or what users would expect.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-19 20:52:52
[2022-02-19 21:25:52] |
Ok gracias, estaré atento a vuestras noticias sobre este tema. :)
