Date/Time: Fri, 07 Mar 2025 00:59:00 +0000
[Programming Help] - Date Range in File does not update to today
View Count: 556
[2022-02-19 10:58:08] |
User119231 - Posts: 7 |
Hello. I opened Sierra today after some months of not using it and downloaded the new data. I use the Sierra Chart feed. The problem is that the platform downloads data up to 2022-01-20. I tried the Delete All Data and Download option and the Download Data From the End of Chart option, I also updated the platform to the latest version but nothing worked. Could you help me with this? |
[2022-02-19 17:28:56] |
You probably are looking at an expired futures contract. Refer to: Futures Chart Not Updating or Not Updating Frequently Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
