Date/Time: Sun, 09 Mar 2025 00:43:12 +0000
Simulation trading for stocks not synchronised
View Count: 496
[2022-02-19 00:39:55] |
RDC - Posts: 9 |
Im trying to get this to work, but there is a lag between all the multiple stock ( minutes and number of bars)charts and the data is not playing very well at all. Previous to the new simulator things were working very well ( not sure why you guys changed it)
[2022-02-19 02:52:29] |
The issue is not clear to us. We need a better description of the problem. There were no changes regarding replay if that is what you are referring to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-19 06:59:18] |
RDC - Posts: 9 |
When I hit replay that is all charts, some charts stay stuck at 10.00am others start at 10.06am with multiple bars missing from the open. Then there is hardly any second by second movement.
[2022-02-28 12:07:15] |
Make sure the replay speed is 1 when you start the replay for multiple charts, then you can later increase it. Before starting the replay, make sure all of the data you expect to see during the replay is actually in the chart. If the data you want to replay is not in the chart, then there will be substantial pauses. Refer to: Chart Data and Chart Data Files: Locating Missing Data in Charts Start by replaying just one single chart and concentrate on any issues with that. Rather than involving multiple charts. ---- Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-28 12:12:56
