Date/Time: Fri, 07 Mar 2025 01:14:02 +0000
Denali data delay
View Count: 516
[2022-02-18 21:57:04] |
Tonkadad - Posts: 235 |
Around 3:20 EST I had no data on CME NQ attached is the heartbeat messages. Did anybody else notice this? |
[2022-02-18 22:16:11] |
This is due to an Internet connectivity issue. Most likely on your side.
[2022-02-18 23:10:18] |
I had IB TWS up at the same time, it didn't stop. If I lose connection it will show red and TWS turns a different color. I was watching the chart closely because I was in a position, after a few seconds I realized the chart wasn't updating, so then I looked at TWS and noticed it was 7 to 8 points above the last price on Denali, after a few more seconds a flurry of bars populated the chart and then Denali was back in sync. Am I the only one who lost data? |
[2022-02-18 23:14:48] |
This definitely was not an issue at the server level. It must have been due to Internet connectivity and you cannot make comparisons to other programs. The path of communication is different. Refer to: Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds Usually a problem like this is going to relate to, a communication issue between your computer and the server going from your computer back to the server. And you can also not compare to TWS because that is not a program which is receiving high data rates. Huge difference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-18 23:23:06
