Date/Time: Fri, 07 Mar 2025 00:56:13 +0000
Incrementing Chart Dates
View Count: 468
[2022-02-18 16:43:21] |
User703411 - Posts: 19 |
Hi, How do I increment my chart by 1 as described in the "Use Evening Session Enabled" section (as attached)? Thanks, Alan, |
[2022-02-18 17:45:50] |
John - SC Support - Posts: 38467 |
That is just stating that you need to add a day in your head, or on paper, to the actual date in order to get the "Trading Day" date for the Evening Session. For example, if your Evening Session starts at 18:00, and you are looking at bars from 18:00-23:59:59 on July 12, then the actual Trading Day for those bars is July 13 (1 day forward). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
