Date/Time: Fri, 07 Mar 2025 00:59:25 +0000
v.2355 - PULL/STACK during replay issue - BUG FIX NEEDED
View Count: 802
[2022-02-18 15:53:56] |
User837706 - Posts: 14 |
I updated to v.2355 earlier last week. I've now rolled back to v.2351 and all is well. PROBLEM: During "chart replay", the DOM's pull stack column does not function properly/ smoothly. It looks like how CQG pull-stack data used to display. You will notice it instantly. Example: I noticed while replaying ZN(Mar 22) contract for today 3pm (GMT) |
[2022-02-18 16:09:52] |
We will check this.
[2022-02-19 03:20:27] |
We identified the issue. It is resolved (a fairly involved issue) and we will have a new release out over the weekend.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-19 03:26:30
[2022-02-20 15:06:29] |
User907968 - Posts: 836 |
Hello, is this issue considered resolved in v2361? There is a major discrepancy between 2347 & 2361 - please see attached chart replay images. |
Attachment Deleted. ![]() |
[2022-02-20 15:12:46] |
No, we have not yet released the solution.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-20 15:12:53
