Date/Time: Tue, 26 Nov 2024 06:24:28 +0000
Is it possible to have a study marker with a lookback update in real time?
View Count: 1216
[2014-04-15 21:29:28] |
cmet - Posts: 551 |
This particular example is with the Delta Divergence indicator. What I'm trying to do: Get the subgraph signal markers (in this case arrows) to show up as the bar is being created. Right now, since there's a lookback period minimum of 1 bar, it only plots after the bar is closed. Is this possible? |
[2014-04-15 23:00:15] |
We did not develop this indicator. It is user contributed is not something we can help with.
