Date/Time: Sun, 04 Oct 2026 17:55:49 +0000
Number bars, delta,...not loading if the program has not been running in that period
View Count: 801
[2022-02-18 13:22:10]
User639371 - Posts: 1
I am having some issues with intraday data. Number bars, cumulative delta and so on is not loading. It only shows data for the period the program has been running. It has never been like that. It is really annoying and for example impossible to see the cummulative delta or the delta by price in the hours the program has been closed (in the overnight for example, or every period the program was closed). Please see attached.
I have already tried to delete and download data, but it does not work. I updated to the current version a few days ago.
Regards,
Javier
imageNumber bars.JPG / V - Attached On 2022-02-18 13:17:51 UTC - Size: 165.92 KB - 220 views
imageDeltabyprice_cumdelta.JPG / V - Attached On 2022-02-18 13:19:47 UTC - Size: 192.49 KB - 274 views
[2022-02-18 15:52:43]
This relates to a change with CQG data. Refer to the notes here for 2351:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351
If you activate the Denali Exchange Data Feed this month, there is no cost for the exchange fees and then you can cancel them through your broker for next month.
