Date/Time: Thu, 06 Mar 2025 22:11:17 +0000
Bringing chart trader open order lines to the front
View Count: 466
[2022-02-17 21:34:34]
User525965 - Posts: 153
Hi, as you can see from this picture, my entry and open order lines are behind chart drawings which can sometimes block them and I can't see the price of my order.
Is there a way to bring the orders to the front so they are clearly displayed?
imageScreenshot_3.png / V - Attached On 2022-02-17 21:34:28 UTC - Size: 2.43 KB - 139 views
[2022-02-17 21:44:16]
John - SC Support - Posts: 38464
There is not a control to bring the Order Lines to the front. Rather what is available is to force the drawings to be at the back. Refer to the following setting and the one after it:
Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
