Date/Time: Thu, 06 Mar 2025 21:56:26 +0000
CL Oil Symbol Rollover Issue
View Count: 511
[2022-02-17 17:58:28]
User274555 - Posts: 14
I am currently trading: CLH22_FUT_CME (March) (Denali/Teton) but SC is prompting me with the "[Volume] Symbol needs Rollover" yellow bar on charts...
When I click it to allow the rollover it perform rollover back into : CLG22_FUT_CME (Feb)...
But then the charts are static, as if they are not receiving data...and the price is stuck @ 86.29 from back in January of 2020.
Are the symbols crossed up somewhere?
-Thanks
[2022-02-17 18:11:58]
John - SC Support - Posts: 38463
When you select the option to Rollover and you get the window that shows the rollover options, you need to select the particular contract from the list on the right. The default entry in that list is not always the next contract. So you would want select the J contract in that list and then select the OK button to get the proper rollover.
You can get to that window by selecting Chart >> Perform Futures Symbol Rollover.
Refer to the following for more instructions:
Changing to a New Futures Contract Month: Changing to a New Futures Contract Month
