Date/Time: Tue, 15 Sep 2026 10:48:44 +0000
Problem historical data feed
View Count: 726
[2022-02-17 16:54:12]
User243133 - Posts: 1
Since this afternoon, it is impossible to download the data of the symbols. Where can this come from? I tried to update, but nothing.
I use AMP and CQG.
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:46:51.920
Requested symbol settings for service code cqg. Request ID: 1. | 2022-02-17 17:46:51.920
Reading Internal Order ID file. | 2022-02-17 17:46:51.932
Reading Trade Orders file. | 2022-02-17 17:46:51.977
Reading Trade Positions file. | 2022-02-17 17:46:51.977
Reading Trade Account Data files. | 2022-02-17 17:46:51.977
Software version: 2357 64-bit | 2022-02-17 17:46:51.990
Primary Thread ID: 4856 | 2022-02-17 17:46:51.990
Usage end date: 2022-03-13 | 2022-02-17 17:46:51.990
Enabled for: Advanced Features 2. | 2022-02-17 17:46:51.990
Enabled for: Sierra Chart Historical Data Service. | 2022-02-17 17:46:51.990
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-17 17:46:51.990
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-17 17:46:51.990
Enabled for exchange2: EUREX EOBI | 2022-02-17 17:46:51.990
Enabled for exchange2: fairx_exchange.data | 2022-02-17 17:46:51.990
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-17 17:46:51.990
Current selected Data/Trading service: CQG WebAPI | 2022-02-17 17:46:51.990
Custom symbol settings values: enabled | 2022-02-17 17:46:51.990
Chart Update Interval: 500 | 2022-02-17 17:46:51.990
Intraday Data Storage Time Unit: 0 | 2022-02-17 17:46:51.990
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2022-02-17 17:46:51.990
2022-02-17 16:46:51 Local computer time in UTC | 2022-02-17 17:46:51.990
2022-02-17 17:46:51 Local computer time in SC Time Zone | 2022-02-17 17:46:51.990
2022-02-17 16:46:49 Server time in UTC | 2022-02-17 17:46:51.990
Local computer UTC time and Server UTC time difference: 2 seconds. | 2022-02-17 17:46:51.990
Program path: E:\GTC\SierraChart\ | 2022-02-17 17:46:51.990
Data Files path: E:\GTC\SierraChart\Data\ | 2022-02-17 17:46:51.990
OS Version Number: 10.0 | 2022-02-17 17:46:51.991
Locale Setting: C | 2022-02-17 17:46:51.991
DLLs: UserContributedStudies_64.dll | 2022-02-17 17:46:51.991
Allowed protected custom studies: | 2022-02-17 17:46:51.991
HTTPS connection ID:2 to login.sierrachart.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. | 2022-02-17 17:46:52.102
HTTPS connection ID:2 to login.sierrachart.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2022-02-17 17:46:52.149
HTTPS connection ID:2 to login.sierrachart.com:443 for request ID:2 (1) | Closed. | 2022-02-17 17:46:52.149
Received 5 login tokens. | 2022-02-17 17:46:52.219
Symbol settings received. Request ID: 1. | 2022-02-17 17:46:53.790
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:46:53.791 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:46:53.791
Using the last loaded symbol settings. | 2022-02-17 17:46:53.791
Requested symbol settings for service code cqg. Request ID: 2. | 2022-02-17 17:46:53.791
Symbol settings received. Request ID: 2. | 2022-02-17 17:46:55.534
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:46:55.535 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:46:55.535
Using the last loaded symbol settings. | 2022-02-17 17:46:55.535
Requested symbol settings for service code cqg. Request ID: 3. | 2022-02-17 17:46:55.535
Symbol settings received. Request ID: 3. | 2022-02-17 17:46:57.212
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:46:57.212 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:46:57.212
Using the last loaded symbol settings. | 2022-02-17 17:46:57.212
Requested symbol settings for service code cqg. Request ID: 4. | 2022-02-17 17:46:57.212
CQG WebAPI | Connecting to server api.cqg.com | 2022-02-17 17:46:58.307
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-02-17 17:46:58.307
CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2022-02-17 17:46:58.307
CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2022-02-17 17:46:58.307
CQG WebSocket socket (2) | Connecting to IP: 195.166.124.165. | 2022-02-17 17:46:58.307
CQG WebSocket | Opening WebSocket. | 2022-02-17 17:46:58.326
CQG WebSocket | Sending WebSocket handshake. | 2022-02-17 17:46:58.326
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-17 17:46:58.385
CQG WebSocket | Server header | Connection: upgrade | 2022-02-17 17:46:58.385
CQG WebSocket | Server header | Sec-WebSocket-Accept: ztZX6Lq6/8C3ypS2lrqL0FNlFms= | 2022-02-17 17:46:58.385
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-02-17 17:46:58.385
CQG WebSocket | Server header | Upgrade: websocket | 2022-02-17 17:46:58.385
CQG WebSocket | Server header | | 2022-02-17 17:46:58.385
CQG WebSocket | Web socket state is now open. | 2022-02-17 17:46:58.385
CQG WebAPI | WebSocket connected. | 2022-02-17 17:46:58.385
CQG WebAPI | Sending market data logon message. | 2022-02-17 17:46:58.385
CQG WebAPI | Base Time: 2022-01-23T06:53:32. 2022-01-23 06:53:32 | 2022-02-17 17:46:58.958
CQG WebAPI | Logon successful. Session Token = xmiWeOEv3mDblWp2cEWxSW6jWTSiKyuC0OmN9asath0AXdFN/uIvdgQJsLXNskNR7FkTIvhdoji | 2022-02-17 17:46:58.958
CQG WebAPI | Connected to server complete. | 2022-02-17 17:46:58.958
Triggering next historical data download in queue. | 2022-02-17 17:46:58.999
Updated verified funded futures trading account ending date to: 2022-03-19 16:46:59 | 2022-02-17 17:46:59.000
CQG WebAPI | Sending Trade Accounts request message. | 2022-02-17 17:46:59.000
Symbol settings received. Request ID: 4. | 2022-02-17 17:46:59.008
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:46:59.009 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:46:59.009
Using the last loaded symbol settings. | 2022-02-17 17:46:59.009
Requested symbol settings for service code cqg. Request ID: 5. | 2022-02-17 17:46:59.009
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:46:59.009
No download requests in the queue to start downloads for. | 2022-02-17 17:46:59.009
CQG WebAPI | Brokerage name: AMP. Account Name: 147012 | 2022-02-17 17:46:59.065
Updated verified funded futures trading account ending date to: 2022-03-19 16:46:59 | 2022-02-17 17:46:59.065
CQG WebAPI | Sending collateral subscribe request. | 2022-02-17 17:46:59.065
Symbol settings received. Request ID: 5. | 2022-02-17 17:47:00.683
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:00.684 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:00.684
Using the last loaded symbol settings. | 2022-02-17 17:47:00.684
Requested symbol settings for service code cqg. Request ID: 6. | 2022-02-17 17:47:00.684
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:00.684
CQG WebAPI | Sending positions subscribe request. RequestID: 222978 | 2022-02-17 17:47:02.005
CQG WebAPI | Sending orders subscribe request. RequestID: 222979 | 2022-02-17 17:47:02.005
Symbol settings received. Request ID: 6. | 2022-02-17 17:47:02.520
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:02.520 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:02.520
Using the last loaded symbol settings. | 2022-02-17 17:47:02.520
Requested symbol settings for service code cqg. Request ID: 7. | 2022-02-17 17:47:02.520
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:02.520
Symbol settings received. Request ID: 7. | 2022-02-17 17:47:04.321
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:04.322 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:04.322
Using the last loaded symbol settings. | 2022-02-17 17:47:04.322
Requested symbol settings for service code cqg. Request ID: 8. | 2022-02-17 17:47:04.322
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:04.322
Symbol settings received. Request ID: 8. | 2022-02-17 17:47:06.030
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:06.031 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:06.031
Using the last loaded symbol settings. | 2022-02-17 17:47:06.031
Requested symbol settings for service code cqg. Request ID: 9. | 2022-02-17 17:47:06.031
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:06.031
Symbol settings received. Request ID: 9. | 2022-02-17 17:47:07.730
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:07.731 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:07.731
Using the last loaded symbol settings. | 2022-02-17 17:47:07.731
Requested symbol settings for service code cqg. Request ID: 10. | 2022-02-17 17:47:07.731
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:07.731
Symbol settings received. Request ID: 10. | 2022-02-17 17:47:09.670
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:09.670 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:09.670
Using the last loaded symbol settings. | 2022-02-17 17:47:09.670
Requested symbol settings for service code cqg. Request ID: 11. | 2022-02-17 17:47:09.670
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:09.670
Symbol settings received. Request ID: 11. | 2022-02-17 17:47:11.417
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:11.418 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:11.418
Using the last loaded symbol settings. | 2022-02-17 17:47:11.418
Requested symbol settings for service code cqg. Request ID: 12. | 2022-02-17 17:47:11.418
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:11.418
Symbol settings received. Request ID: 12. | 2022-02-17 17:47:13.095
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:13.095 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:13.095
Using the last loaded symbol settings. | 2022-02-17 17:47:13.095
Requested symbol settings for service code cqg. Request ID: 13. | 2022-02-17 17:47:13.095
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:13.095
File >> Disconnect selected. | 2022-02-17 17:47:13.519
CQG WebAPI | Sending Web API Logoff message. | 2022-02-17 17:47:13.519
CQG WebSocket socket (2) | CloseSocket call. | 2022-02-17 17:47:13.519
CQG WebSocket | WebSocket closed. | 2022-02-17 17:47:13.519
CQG WebAPI | WebSocket closed. | 2022-02-17 17:47:13.519
CQG WebAPI | Disconnected. | 2022-02-17 17:47:13.520
CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-02-17 17:47:13.520
CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2022-02-17 17:47:13.535
CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. | 2022-02-17 17:47:13.535
Symbol settings received. Request ID: 13. | 2022-02-17 17:47:14.884
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:14.884 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:14.884
Using the last loaded symbol settings. | 2022-02-17 17:47:14.884
Requested symbol settings for service code cqg. Request ID: 14. | 2022-02-17 17:47:14.884
Symbol settings received. Request ID: 14. | 2022-02-17 17:47:16.656
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:16.656 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:16.656
Using the last loaded symbol settings. | 2022-02-17 17:47:16.656
Requested symbol settings for service code cqg. Request ID: 15. | 2022-02-17 17:47:16.656
Symbol settings received. Request ID: 15. | 2022-02-17 17:47:18.435
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:18.435 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:18.436
Using the last loaded symbol settings. | 2022-02-17 17:47:18.436
Requested symbol settings for service code cqg. Request ID: 16. | 2022-02-17 17:47:18.436
CQG WebAPI | Connecting to server api.cqg.com | 2022-02-17 17:47:18.463
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-02-17 17:47:18.463
CQG WebSocket socket (4) | Creating socket. Using TLS 1.2. | 2022-02-17 17:47:18.464
CQG WebSocket socket (4) | New receive buffer size: 5242880 | 2022-02-17 17:47:18.464
CQG WebSocket socket (4) | Connecting to IP: 195.166.124.165. | 2022-02-17 17:47:18.464
CQG WebSocket | Opening WebSocket. | 2022-02-17 17:47:18.487
CQG WebSocket | Sending WebSocket handshake. | 2022-02-17 17:47:18.487
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-17 17:47:18.548
CQG WebSocket | Server header | Connection: upgrade | 2022-02-17 17:47:18.548
CQG WebSocket | Server header | Sec-WebSocket-Accept: WyJsO/XifDdJ3a6i0UD2B2jjfgU= | 2022-02-17 17:47:18.548
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-02-17 17:47:18.548
CQG WebSocket | Server header | Upgrade: websocket | 2022-02-17 17:47:18.548
CQG WebSocket | Server header | | 2022-02-17 17:47:18.548
CQG WebSocket | Web socket state is now open. | 2022-02-17 17:47:18.548
CQG WebAPI | WebSocket connected. | 2022-02-17 17:47:18.548
CQG WebAPI | Sending market data logon message. | 2022-02-17 17:47:18.548
CQG WebAPI | Base Time: 2022-01-23T06:53:32. 2022-01-23 06:53:32 | 2022-02-17 17:47:19.152
CQG WebAPI | Logon successful. Session Token = oKfEvdEMCevpMTtZyMLMHY+grdssOzwZr/OjAMyrh70YqF5nWe/C0Il1n/rUFK9aioaYF1t6Cpe | 2022-02-17 17:47:19.152
CQG WebAPI | Connected to server complete. | 2022-02-17 17:47:19.152
Triggering next historical data download in queue. | 2022-02-17 17:47:19.153
Updated verified funded futures trading account ending date to: 2022-03-19 16:47:19 | 2022-02-17 17:47:19.153
CQG WebAPI | Sending Trade Accounts request message. | 2022-02-17 17:47:19.153
No download requests in the queue to start downloads for. | 2022-02-17 17:47:19.153
CQG WebAPI | Brokerage name: AMP. Account Name: 147012 | 2022-02-17 17:47:19.219
Updated verified funded futures trading account ending date to: 2022-03-19 16:47:19 | 2022-02-17 17:47:19.219
CQG WebAPI | Sending collateral subscribe request. | 2022-02-17 17:47:19.219
Symbol settings received. Request ID: 16. | 2022-02-17 17:47:20.194
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:20.195 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:20.195
Using the last loaded symbol settings. | 2022-02-17 17:47:20.195
Requested symbol settings for service code cqg. Request ID: 17. | 2022-02-17 17:47:20.195
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:20.195
Symbol settings received. Request ID: 17. | 2022-02-17 17:47:21.866
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:21.866 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:21.866
Using the last loaded symbol settings. | 2022-02-17 17:47:21.866
Requested symbol settings for service code cqg. Request ID: 18. | 2022-02-17 17:47:21.866
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:21.866
CQG WebAPI | Sending positions subscribe request. RequestID: 222982 | 2022-02-17 17:47:22.151
CQG WebAPI | Sending orders subscribe request. RequestID: 222983 | 2022-02-17 17:47:22.151
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.825 *
Chart (F.US.DBH22) | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.826 *
F.US.DBH22 [CBV] #3 | Reloading chart. | 2022-02-17 17:47:22.826
F.US.DBH22 [CBV] #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-17 17:47:22.826
F.US.DBH22 [CBV] #3 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-17 17:47:22.826
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.827 *
F.US.DBH22 [CBV] #3 | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.827 *
Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.831 *
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.843 *
Chart (F.US.DBH22) | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.844 *
F.US.DBH22 #1 | Reloading chart. | 2022-02-17 17:47:22.844
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.846 *
F.US.DBH22 #1 | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.846 *
Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.852 *
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.869 *
Chart (F.US.DBH22) | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.869 *
F.US.DBH22 0.03 Range #2 | Reloading chart. | 2022-02-17 17:47:22.870
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.872 *
F.US.DBH22 0.03 Range #2 | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.872 *
Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.879 *
F.US.DDH22 1 Min #4 | Reloading chart. | 2022-02-17 17:47:22.896
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.919 *
Chart (F.US.DBH22) | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.920 *
F.US.DBH22 5 Min #8 | Reloading chart. | 2022-02-17 17:47:22.920
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.921 *
F.US.DBH22 5 Min #8 | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.921 *
Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.925 *
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.951 *
Chart (F.US.DBH22) | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.951 *
F.US.DBH22 [CBV] 1 Min #7 | Reloading chart. | 2022-02-17 17:47:22.952
F.US.DBH22 [CBV] 1 Min #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-17 17:47:22.952
F.US.DBH22 [CBV] 1 Min #7 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-17 17:47:22.952
Error creating Intraday data file: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.957 *
F.US.DBH22 [CBV] 1 Min #7 | Failed to get dates from Intraday data file. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.957 *
Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for reading. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.961 *
F.US.DBH22 [CBV-D] #3 | Error opening or reading chart data file. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.965 *
F.US.DBH22 #1 | Error opening or reading chart data file. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.973 *
F.US.DBH22 0.03 Range #2 | Error opening or reading chart data file. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.978 *
F.US.DBH22 5 Min #8 | Error opening or reading chart data file. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.983 *
F.US.DBH22 [CBV-D] 1 Min #7 | Error opening or reading chart data file. File: E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:22.987 *
Using symbol data fast lookup vector | 2022-02-17 17:47:23.330
CQG WebAPI | Starting real-time market data updates for: F.US.DBH22. ID: 1 | 2022-02-17 17:47:23.331
CQG WebAPI | Sending symbol resolution request for F.US.DBH22. ID: 222984 | 2022-02-17 17:47:23.331
CQG WebAPI | Requesting security definition data for: F.US.DBH22. ID: 1 | 2022-02-17 17:47:23.331
CQG WebAPI | Using primary service for historical data for F.US.DBH22 | 2022-02-17 17:47:23.331
Starting DelayedDownloadMonitoringTimer | 2022-02-17 17:47:23.331
Starting HDTimeoutTimer | 2022-02-17 17:47:23.331
Added historical Intraday data request for F.US.DBH22 to the queue. | 2022-02-17 17:47:23.331
Intraday data recording state for symbol F.US.DBH22 is set to download 'Pending'. | 2022-02-17 17:47:23.331
Triggering next historical data download in queue. | 2022-02-17 17:47:23.331
Delaying start of download for F.US.DBH22 | 2022-02-17 17:47:23.331
CQG WebAPI | Received symbol resolution report for symbol F.US.DBH22. Search Symbol: F.US.DBH22. Request ID: 222984. Contract ID: 1. | 2022-02-17 17:47:23.347
CQG WebAPI | Requesting market data for F.US.DBH22 | 2022-02-17 17:47:23.347
CQG WebAPI | Starting real-time market data updates for: F.US.DDH22. ID: 2 | 2022-02-17 17:47:23.389
CQG WebAPI | Sending symbol resolution request for F.US.DDH22. ID: 222985 | 2022-02-17 17:47:23.389
CQG WebAPI | Requesting security definition data for: F.US.DDH22. ID: 2 | 2022-02-17 17:47:23.389
CQG WebAPI | Using primary service for historical data for F.US.DDH22 | 2022-02-17 17:47:23.389
Added historical Intraday data request for F.US.DDH22 to the queue. | 2022-02-17 17:47:23.389
Intraday data recording state for symbol F.US.DDH22 is set to download 'Pending'. | 2022-02-17 17:47:23.389
Triggering next historical data download in queue. | 2022-02-17 17:47:23.389
CQG WebAPI | Received symbol resolution report for symbol F.US.DDH22. Search Symbol: F.US.DDH22. Request ID: 222985. Contract ID: 2. | 2022-02-17 17:47:23.405
CQG WebAPI | Requesting market data for F.US.DDH22 | 2022-02-17 17:47:23.405
Symbol settings received. Request ID: 18. | 2022-02-17 17:47:23.535
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:23.536 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:23.536
Using the last loaded symbol settings. | 2022-02-17 17:47:23.536
Requested symbol settings for service code cqg. Request ID: 19. | 2022-02-17 17:47:23.536
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:23.536
F.US.DDH22 1 Min #4 | StartDateTimeForLoadingOrderFills: 2021-12-02 02:57:00 | 2022-02-17 17:47:23.659
Requesting market depth updates for: F.US.DBH22 if supported. | 2022-02-17 17:47:24.155
CQG WebAPI | Requesting market data including full depth for F.US.DBH22 | 2022-02-17 17:47:24.155
Symbol settings received. Request ID: 19. | 2022-02-17 17:47:25.293
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:25.293 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:25.293
Using the last loaded symbol settings. | 2022-02-17 17:47:25.293
Requested symbol settings for service code cqg. Request ID: 20. | 2022-02-17 17:47:25.293
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:25.293
Symbol settings received. Request ID: 20. | 2022-02-17 17:47:27.070
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:27.070 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:27.070
Using the last loaded symbol settings. | 2022-02-17 17:47:27.070
Requested symbol settings for service code cqg. Request ID: 21. | 2022-02-17 17:47:27.070
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:27.070
HD Request # 1 | Downloading Intraday chart data for F.US.DBH22 to the file F.US.DBH22.scid. Service: cqg | 2022-02-17 17:47:28.348
Error getting file attributes for E:\GTC\SierraChart\Data\F.US.DBH22.scid. Unable to check read-only status. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:28.348
HD Request # 1 | Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid. Error: Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. Failed to open the Intraday data file for download. | 2022-02-17 17:47:28.348
HD Request # 1 | Error downloading historical Intraday data for F.US.DBH22. Not downloading any Intraday data for symbol F.US.DBH22. | 2022-02-17 17:47:28.348
HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.DBH22 | 2022-02-17 17:47:28.348
Error getting file attributes for E:\GTC\SierraChart\Data\F.US.DBH22.scid. Unable to check read-only status. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:28.349
HD Request # 1 | Error opening Intraday data files to add Time and Sales records. Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for adding records. Error: Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:28.349 *
HD Request # 1 | Completion time: 0s | 2022-02-17 17:47:28.349
HD Request # 1 | Intraday data download complete for F.US.DBH22. Unique request ID: 1 | 2022-02-17 17:47:28.349
Removing historical data download ID 1. | 2022-02-17 17:47:28.349
Real-time Intraday chart data file updates started for F.US.DBH22 | 2022-02-17 17:47:28.349
Intraday chart data file opened for F.US.DBH22 | 2022-02-17 17:47:28.349
HD Request # 1 | Enabling Intraday chart updating for symbol. | 2022-02-17 17:47:28.349
Triggering next historical data download in queue. | 2022-02-17 17:47:28.349
HD Request # 2 | Downloading Intraday chart data for F.US.DDH22 to the file F.US.DDH22.scid. Service: cqg | 2022-02-17 17:47:28.349
HD Request # 2 | Download start date-time: 2022-02-17 17:44:14.000000. File last date-time: 2022-02-17 17:44:14.860000 | 2022-02-17 17:47:28.389
HD Request # 2 | Requesting historical Tick data. | 2022-02-17 17:47:28.389
HD Request # 2 | Receiving Intraday data for F.US.DDH22 starting at 2022-02-17 17:44:14.860000 | 2022-02-17 17:47:28.497
HD Request # 2 | Timestamp of first Intraday data file record written: 2022-02-17 17:44:17.004000 | 2022-02-17 17:47:28.498
HD Request # 2 | Received 70 Intraday data records from 2022-02-17 17:44:14.860000 to 2022-02-17 17:47:21.580000 (3.1 minutes) and wrote 69 records for F.US.DDH22 | 2022-02-17 17:47:28.498
HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2022-02-17 16:47:21.580000 | 2022-02-17 17:47:28.527
HD Request # 2 | Completion time: 0s | 2022-02-17 17:47:28.528
HD Request # 2 | Intraday data download complete for F.US.DDH22. Unique request ID: 2 | 2022-02-17 17:47:28.528
Removing historical data download ID 2. | 2022-02-17 17:47:28.528
Real-time Intraday chart data file updates started for F.US.DDH22 | 2022-02-17 17:47:28.528
Intraday chart data file opened for F.US.DDH22 | 2022-02-17 17:47:28.528
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2022-02-17 17:47:28.528
Triggering next historical data download in queue. | 2022-02-17 17:47:28.528
No download requests in the queue to start downloads for. | 2022-02-17 17:47:28.528
Symbol settings received. Request ID: 21. | 2022-02-17 17:47:28.763
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:28.763 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:28.763
Using the last loaded symbol settings. | 2022-02-17 17:47:28.763
Requested symbol settings for service code cqg. Request ID: 22. | 2022-02-17 17:47:28.763
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:28.763
Symbol settings received. Request ID: 22. | 2022-02-17 17:47:30.468
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:30.469 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:30.469
Using the last loaded symbol settings. | 2022-02-17 17:47:30.469
Requested symbol settings for service code cqg. Request ID: 23. | 2022-02-17 17:47:30.469
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:30.469
Symbol settings received. Request ID: 23. | 2022-02-17 17:47:32.190
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:32.190 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:32.190
Using the last loaded symbol settings. | 2022-02-17 17:47:32.190
Requested symbol settings for service code cqg. Request ID: 24. | 2022-02-17 17:47:32.190
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:32.190
Symbol settings received. Request ID: 24. | 2022-02-17 17:47:33.897
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:33.898 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:33.898
Using the last loaded symbol settings. | 2022-02-17 17:47:33.898
Requested symbol settings for service code cqg. Request ID: 25. | 2022-02-17 17:47:33.898
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:33.898
Symbol settings received. Request ID: 25. | 2022-02-17 17:47:35.679
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:35.679 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:35.679
Using the last loaded symbol settings. | 2022-02-17 17:47:35.679
Requested symbol settings for service code cqg. Request ID: 26. | 2022-02-17 17:47:35.679
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:35.679
Opened cached Intraday file: E:\GTC\SierraChart\Data\F.US.DDH22.scid. Thread ID: 7224 | 2022-02-17 17:47:37.423
Symbol settings received. Request ID: 26. | 2022-02-17 17:47:37.558
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:37.558 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:37.558
Using the last loaded symbol settings. | 2022-02-17 17:47:37.558
Requested symbol settings for service code cqg. Request ID: 27. | 2022-02-17 17:47:37.558
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:37.558
Symbol settings received. Request ID: 27. | 2022-02-17 17:47:39.273
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:39.273 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:39.273
Using the last loaded symbol settings. | 2022-02-17 17:47:39.273
Requested symbol settings for service code cqg. Request ID: 28. | 2022-02-17 17:47:39.273
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:39.273
Symbol settings received. Request ID: 28. | 2022-02-17 17:47:41.071
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:41.072 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:41.072
Using the last loaded symbol settings. | 2022-02-17 17:47:41.072
Requested symbol settings for service code cqg. Request ID: 29. | 2022-02-17 17:47:41.072
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:41.072
Symbol settings received. Request ID: 29. | 2022-02-17 17:47:42.809
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:42.809 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:42.809
Using the last loaded symbol settings. | 2022-02-17 17:47:42.809
Requested symbol settings for service code cqg. Request ID: 30. | 2022-02-17 17:47:42.810
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:42.810
Symbol settings received. Request ID: 30. | 2022-02-17 17:47:44.494
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:44.494 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:44.494
Using the last loaded symbol settings. | 2022-02-17 17:47:44.494
Requested symbol settings for service code cqg. Request ID: 31. | 2022-02-17 17:47:44.494
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:44.494
Symbol settings received. Request ID: 31. | 2022-02-17 17:47:46.315
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:46.316 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:46.316
Using the last loaded symbol settings. | 2022-02-17 17:47:46.316
Requested symbol settings for service code cqg. Request ID: 32. | 2022-02-17 17:47:46.316
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:46.316
Error getting file attributes for E:\GTC\SierraChart\Data\F.US.DBH22.scid. Unable to check read-only status. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:47.510
Error opening Intraday file: Failed to open the file E:\GTC\SierraChart\Data\F.US.DBH22.scid for adding records. Error: Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:47.510 *
Symbol settings received. Request ID: 32. | 2022-02-17 17:47:48.261
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:48.261 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:48.261
Using the last loaded symbol settings. | 2022-02-17 17:47:48.261
Requested symbol settings for service code cqg. Request ID: 33. | 2022-02-17 17:47:48.261
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:48.261
File open error encountered. Not allowing writing. E:\GTC\SierraChart\Data\F.US.DBH22.scid | 2022-02-17 17:47:48.938
Symbol settings received. Request ID: 33. | 2022-02-17 17:47:50.095
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:50.095 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:50.096
Using the last loaded symbol settings. | 2022-02-17 17:47:50.096
Requested symbol settings for service code cqg. Request ID: 34. | 2022-02-17 17:47:50.096
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:50.096
Symbol settings received. Request ID: 34. | 2022-02-17 17:47:52.053
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:52.053 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:52.053
Using the last loaded symbol settings. | 2022-02-17 17:47:52.053
Requested symbol settings for service code cqg. Request ID: 35. | 2022-02-17 17:47:52.053
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:52.053
Symbol settings received. Request ID: 35. | 2022-02-17 17:47:53.791
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:53.792 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:53.792
Using the last loaded symbol settings. | 2022-02-17 17:47:53.792
Requested symbol settings for service code cqg. Request ID: 36. | 2022-02-17 17:47:53.792
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:53.792
Symbol settings received. Request ID: 36. | 2022-02-17 17:47:55.568
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:55.568 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:55.568
Using the last loaded symbol settings. | 2022-02-17 17:47:55.568
Requested symbol settings for service code cqg. Request ID: 37. | 2022-02-17 17:47:55.568
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:55.568
Symbol settings received. Request ID: 37. | 2022-02-17 17:47:57.288
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:57.288 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:57.288
Using the last loaded symbol settings. | 2022-02-17 17:47:57.288
Requested symbol settings for service code cqg. Request ID: 38. | 2022-02-17 17:47:57.288
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:57.288
Symbol settings received. Request ID: 38. | 2022-02-17 17:47:58.967
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:47:58.967 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:47:58.967
Using the last loaded symbol settings. | 2022-02-17 17:47:58.967
Requested symbol settings for service code cqg. Request ID: 39. | 2022-02-17 17:47:58.967
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:47:58.967
Symbol settings received. Request ID: 39. | 2022-02-17 17:48:00.751
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:00.751 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:00.751
Using the last loaded symbol settings. | 2022-02-17 17:48:00.751
Requested symbol settings for service code cqg. Request ID: 40. | 2022-02-17 17:48:00.752
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:00.752
Symbol settings received. Request ID: 40. | 2022-02-17 17:48:02.520
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:02.520 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:02.520
Using the last loaded symbol settings. | 2022-02-17 17:48:02.520
Requested symbol settings for service code cqg. Request ID: 41. | 2022-02-17 17:48:02.521
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:02.521
Symbol settings received. Request ID: 41. | 2022-02-17 17:48:04.333
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:04.334 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:04.334
Using the last loaded symbol settings. | 2022-02-17 17:48:04.334
Requested symbol settings for service code cqg. Request ID: 42. | 2022-02-17 17:48:04.334
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:04.334
Symbol settings received. Request ID: 42. | 2022-02-17 17:48:06.023
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:06.024 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:06.024
Using the last loaded symbol settings. | 2022-02-17 17:48:06.024
Requested symbol settings for service code cqg. Request ID: 43. | 2022-02-17 17:48:06.024
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:06.024
Symbol settings received. Request ID: 43. | 2022-02-17 17:48:07.735
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:07.735 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:07.735
Using the last loaded symbol settings. | 2022-02-17 17:48:07.735
Requested symbol settings for service code cqg. Request ID: 44. | 2022-02-17 17:48:07.739
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:07.739
Symbol settings received. Request ID: 44. | 2022-02-17 17:48:09.535
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:09.535 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:09.535
Using the last loaded symbol settings. | 2022-02-17 17:48:09.535
Requested symbol settings for service code cqg. Request ID: 45. | 2022-02-17 17:48:09.535
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:09.535
Symbol settings received. Request ID: 45. | 2022-02-17 17:48:11.353
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:11.353 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:11.353
Using the last loaded symbol settings. | 2022-02-17 17:48:11.353
Requested symbol settings for service code cqg. Request ID: 46. | 2022-02-17 17:48:11.353
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:11.353
Symbol settings received. Request ID: 46. | 2022-02-17 17:48:13.034
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:13.035 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:13.035
Using the last loaded symbol settings. | 2022-02-17 17:48:13.035
Requested symbol settings for service code cqg. Request ID: 47. | 2022-02-17 17:48:13.035
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:13.035
Symbol settings received. Request ID: 47. | 2022-02-17 17:48:14.805
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:14.805 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:14.805
Using the last loaded symbol settings. | 2022-02-17 17:48:14.805
Requested symbol settings for service code cqg. Request ID: 48. | 2022-02-17 17:48:14.805
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:14.805
Symbol settings received. Request ID: 48. | 2022-02-17 17:48:16.469
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:16.469 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:16.469
Using the last loaded symbol settings. | 2022-02-17 17:48:16.469
Requested symbol settings for service code cqg. Request ID: 49. | 2022-02-17 17:48:16.470
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:16.470
Symbol settings received. Request ID: 49. | 2022-02-17 17:48:18.264
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:18.264 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:18.264
Using the last loaded symbol settings. | 2022-02-17 17:48:18.264
Requested symbol settings for service code cqg. Request ID: 50. | 2022-02-17 17:48:18.264
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:18.264
Symbol settings received. Request ID: 50. | 2022-02-17 17:48:19.992
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:19.992 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:19.992
Using the last loaded symbol settings. | 2022-02-17 17:48:19.993
Requested symbol settings for service code cqg. Request ID: 51. | 2022-02-17 17:48:19.993
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:19.993
Symbol settings received. Request ID: 51. | 2022-02-17 17:48:21.647
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:21.647 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:21.647
Using the last loaded symbol settings. | 2022-02-17 17:48:21.647
Requested symbol settings for service code cqg. Request ID: 52. | 2022-02-17 17:48:21.647
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:21.647
Symbol settings received. Request ID: 52. | 2022-02-17 17:48:23.366
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:23.367 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:23.367
Using the last loaded symbol settings. | 2022-02-17 17:48:23.367
Requested symbol settings for service code cqg. Request ID: 53. | 2022-02-17 17:48:23.367
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:23.367
Symbol settings received. Request ID: 53. | 2022-02-17 17:48:25.199
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:25.199 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:25.200
Using the last loaded symbol settings. | 2022-02-17 17:48:25.200
Requested symbol settings for service code cqg. Request ID: 54. | 2022-02-17 17:48:25.200
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:25.200
Symbol settings received. Request ID: 54. | 2022-02-17 17:48:26.887
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:26.888 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:26.888
Using the last loaded symbol settings. | 2022-02-17 17:48:26.888
Requested symbol settings for service code cqg. Request ID: 55. | 2022-02-17 17:48:26.888
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:26.888
Symbol settings received. Request ID: 55. | 2022-02-17 17:48:28.697
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:28.698 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:28.698
Using the last loaded symbol settings. | 2022-02-17 17:48:28.698
Requested symbol settings for service code cqg. Request ID: 56. | 2022-02-17 17:48:28.698
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:28.698
Symbol settings received. Request ID: 56. | 2022-02-17 17:48:30.418
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:30.418 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:30.418
Using the last loaded symbol settings. | 2022-02-17 17:48:30.418
Requested symbol settings for service code cqg. Request ID: 57. | 2022-02-17 17:48:30.419
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:30.419
Symbol settings received. Request ID: 57. | 2022-02-17 17:48:32.152
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:32.152 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:32.152
Using the last loaded symbol settings. | 2022-02-17 17:48:32.152
Requested symbol settings for service code cqg. Request ID: 58. | 2022-02-17 17:48:32.152
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:32.152
Symbol settings received. Request ID: 58. | 2022-02-17 17:48:33.870
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:33.871 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:33.871
Using the last loaded symbol settings. | 2022-02-17 17:48:33.871
Requested symbol settings for service code cqg. Request ID: 59. | 2022-02-17 17:48:33.871
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:33.871
Symbol settings received. Request ID: 59. | 2022-02-17 17:48:35.598
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:35.599 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:35.599
Using the last loaded symbol settings. | 2022-02-17 17:48:35.599
Requested symbol settings for service code cqg. Request ID: 60. | 2022-02-17 17:48:35.599
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:35.599
Symbol settings received. Request ID: 60. | 2022-02-17 17:48:37.331
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:37.332 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:37.332
Using the last loaded symbol settings. | 2022-02-17 17:48:37.332
Requested symbol settings for service code cqg. Request ID: 61. | 2022-02-17 17:48:37.332
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:37.332
Symbol settings received. Request ID: 61. | 2022-02-17 17:48:39.091
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:39.092 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:39.092
Using the last loaded symbol settings. | 2022-02-17 17:48:39.092
Requested symbol settings for service code cqg. Request ID: 62. | 2022-02-17 17:48:39.092
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:39.092
Symbol settings received. Request ID: 62. | 2022-02-17 17:48:40.939
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:40.939 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:40.939
Using the last loaded symbol settings. | 2022-02-17 17:48:40.939
Requested symbol settings for service code cqg. Request ID: 63. | 2022-02-17 17:48:40.939
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:40.939
Symbol settings received. Request ID: 63. | 2022-02-17 17:48:42.693
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:42.693 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:42.693
Using the last loaded symbol settings. | 2022-02-17 17:48:42.693
Requested symbol settings for service code cqg. Request ID: 64. | 2022-02-17 17:48:42.693
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:42.693
Symbol settings received. Request ID: 64. | 2022-02-17 17:48:44.428
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:44.428 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:44.428
Using the last loaded symbol settings. | 2022-02-17 17:48:44.428
Requested symbol settings for service code cqg. Request ID: 65. | 2022-02-17 17:48:44.428
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:44.428
Symbol settings received. Request ID: 65. | 2022-02-17 17:48:46.228
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:46.229 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:46.229
Using the last loaded symbol settings. | 2022-02-17 17:48:46.229
Requested symbol settings for service code cqg. Request ID: 66. | 2022-02-17 17:48:46.229
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:46.229
Symbol settings received. Request ID: 66. | 2022-02-17 17:48:47.950
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:47.950 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:47.950
Using the last loaded symbol settings. | 2022-02-17 17:48:47.950
Requested symbol settings for service code cqg. Request ID: 67. | 2022-02-17 17:48:47.950
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:47.950
Symbol settings received. Request ID: 67. | 2022-02-17 17:48:49.785
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:49.785 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:49.785
Using the last loaded symbol settings. | 2022-02-17 17:48:49.785
Requested symbol settings for service code cqg. Request ID: 68. | 2022-02-17 17:48:49.785
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:49.785
Symbol settings received. Request ID: 68. | 2022-02-17 17:48:51.536
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:51.537 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:51.537
Using the last loaded symbol settings. | 2022-02-17 17:48:51.537
Requested symbol settings for service code cqg. Request ID: 69. | 2022-02-17 17:48:51.537
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:51.537
Symbol settings received. Request ID: 69. | 2022-02-17 17:48:53.284
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:53.285 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:53.285
Using the last loaded symbol settings. | 2022-02-17 17:48:53.285
Requested symbol settings for service code cqg. Request ID: 70. | 2022-02-17 17:48:53.285
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:53.285
Symbol settings received. Request ID: 70. | 2022-02-17 17:48:55.048
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:55.049 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:55.049
Using the last loaded symbol settings. | 2022-02-17 17:48:55.049
Requested symbol settings for service code cqg. Request ID: 71. | 2022-02-17 17:48:55.049
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:55.049
Symbol settings received. Request ID: 71. | 2022-02-17 17:48:56.814
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:56.814 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:56.814
Using the last loaded symbol settings. | 2022-02-17 17:48:56.814
Requested symbol settings for service code cqg. Request ID: 72. | 2022-02-17 17:48:56.814
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:56.814
Symbol settings received. Request ID: 72. | 2022-02-17 17:48:58.493
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:48:58.493 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:48:58.493
Using the last loaded symbol settings. | 2022-02-17 17:48:58.494
Requested symbol settings for service code cqg. Request ID: 73. | 2022-02-17 17:48:58.494
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:48:58.494
Symbol settings received. Request ID: 73. | 2022-02-17 17:49:00.336
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:00.337 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:00.337
Using the last loaded symbol settings. | 2022-02-17 17:49:00.337
Requested symbol settings for service code cqg. Request ID: 74. | 2022-02-17 17:49:00.337
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:00.337
Symbol settings received. Request ID: 74. | 2022-02-17 17:49:02.157
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:02.157 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:02.157
Using the last loaded symbol settings. | 2022-02-17 17:49:02.157
Requested symbol settings for service code cqg. Request ID: 75. | 2022-02-17 17:49:02.157
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:02.157
Symbol settings received. Request ID: 75. | 2022-02-17 17:49:04.089
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:04.089 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:04.089
Using the last loaded symbol settings. | 2022-02-17 17:49:04.089
Requested symbol settings for service code cqg. Request ID: 76. | 2022-02-17 17:49:04.089
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:04.089
Symbol settings received. Request ID: 76. | 2022-02-17 17:49:05.862
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:05.862 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:05.862
Using the last loaded symbol settings. | 2022-02-17 17:49:05.862
Requested symbol settings for service code cqg. Request ID: 77. | 2022-02-17 17:49:05.862
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:05.862
Symbol settings received. Request ID: 77. | 2022-02-17 17:49:07.606
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:07.607 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:07.607
Using the last loaded symbol settings. | 2022-02-17 17:49:07.607
Requested symbol settings for service code cqg. Request ID: 78. | 2022-02-17 17:49:07.607
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:07.607
Symbol settings received. Request ID: 78. | 2022-02-17 17:49:09.355
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:09.355 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:09.355
Using the last loaded symbol settings. | 2022-02-17 17:49:09.355
Requested symbol settings for service code cqg. Request ID: 79. | 2022-02-17 17:49:09.355
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:09.355
Symbol settings received. Request ID: 79. | 2022-02-17 17:49:11.130
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:11.130 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:11.130
Using the last loaded symbol settings. | 2022-02-17 17:49:11.130
Requested symbol settings for service code cqg. Request ID: 80. | 2022-02-17 17:49:11.130
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:11.130
Symbol settings received. Request ID: 80. | 2022-02-17 17:49:12.860
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:12.860 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:12.861
Using the last loaded symbol settings. | 2022-02-17 17:49:12.861
Requested symbol settings for service code cqg. Request ID: 81. | 2022-02-17 17:49:12.861
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:12.861
Symbol settings received. Request ID: 81. | 2022-02-17 17:49:14.623
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:14.623 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:14.623
Using the last loaded symbol settings. | 2022-02-17 17:49:14.623
Requested symbol settings for service code cqg. Request ID: 82. | 2022-02-17 17:49:14.623
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:14.623
Symbol settings received. Request ID: 82. | 2022-02-17 17:49:16.398
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:16.398 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:16.398
Using the last loaded symbol settings. | 2022-02-17 17:49:16.398
Requested symbol settings for service code cqg. Request ID: 83. | 2022-02-17 17:49:16.398
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:16.398
Symbol settings received. Request ID: 83. | 2022-02-17 17:49:18.123
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:18.123 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:18.123
Using the last loaded symbol settings. | 2022-02-17 17:49:18.123
Requested symbol settings for service code cqg. Request ID: 84. | 2022-02-17 17:49:18.124
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:18.124
Symbol settings received. Request ID: 84. | 2022-02-17 17:49:19.866
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:19.867 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:19.867
Using the last loaded symbol settings. | 2022-02-17 17:49:19.867
Requested symbol settings for service code cqg. Request ID: 85. | 2022-02-17 17:49:19.867
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:19.867
Symbol settings received. Request ID: 85. | 2022-02-17 17:49:21.713
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:21.714 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:21.714
Using the last loaded symbol settings. | 2022-02-17 17:49:21.714
Requested symbol settings for service code cqg. Request ID: 86. | 2022-02-17 17:49:21.714
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:21.714
Symbol settings received. Request ID: 86. | 2022-02-17 17:49:23.431
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:23.431 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:23.431
Using the last loaded symbol settings. | 2022-02-17 17:49:23.431
Requested symbol settings for service code cqg. Request ID: 87. | 2022-02-17 17:49:23.431
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:23.431
Symbol settings received. Request ID: 87. | 2022-02-17 17:49:25.281
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:25.282 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:25.282
Using the last loaded symbol settings. | 2022-02-17 17:49:25.282
Requested symbol settings for service code cqg. Request ID: 88. | 2022-02-17 17:49:25.282
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:25.282
Symbol settings received. Request ID: 88. | 2022-02-17 17:49:27.001
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:27.002 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:27.002
Using the last loaded symbol settings. | 2022-02-17 17:49:27.002
Requested symbol settings for service code cqg. Request ID: 89. | 2022-02-17 17:49:27.002
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:27.002
Symbol settings received. Request ID: 89. | 2022-02-17 17:49:28.724
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:28.725 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:28.725
Using the last loaded symbol settings. | 2022-02-17 17:49:28.725
Requested symbol settings for service code cqg. Request ID: 90. | 2022-02-17 17:49:28.725
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:28.725
Symbol settings received. Request ID: 90. | 2022-02-17 17:49:30.395
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:30.395 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:30.395
Using the last loaded symbol settings. | 2022-02-17 17:49:30.395
Requested symbol settings for service code cqg. Request ID: 91. | 2022-02-17 17:49:30.396
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:30.396
Symbol settings received. Request ID: 91. | 2022-02-17 17:49:32.169
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:32.170 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:32.170
Using the last loaded symbol settings. | 2022-02-17 17:49:32.170
Requested symbol settings for service code cqg. Request ID: 92. | 2022-02-17 17:49:32.170
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:32.170
Symbol settings received. Request ID: 92. | 2022-02-17 17:49:33.912
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:33.912 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:33.912
Using the last loaded symbol settings. | 2022-02-17 17:49:33.912
Requested symbol settings for service code cqg. Request ID: 93. | 2022-02-17 17:49:33.912
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:33.912
Symbol settings received. Request ID: 93. | 2022-02-17 17:49:35.569
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:35.570 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:35.570
Using the last loaded symbol settings. | 2022-02-17 17:49:35.570
Requested symbol settings for service code cqg. Request ID: 94. | 2022-02-17 17:49:35.570
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:35.570
Symbol settings received. Request ID: 94. | 2022-02-17 17:49:37.334
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:37.334 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:37.334
Using the last loaded symbol settings. | 2022-02-17 17:49:37.334
Requested symbol settings for service code cqg. Request ID: 95. | 2022-02-17 17:49:37.334
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:37.334
CQG WebSocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-02-17 17:49:37.731
CQG WebSocket socket (2) | Closed. | 2022-02-17 17:49:37.731
Symbol settings received. Request ID: 95. | 2022-02-17 17:49:39.101
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:39.101 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:39.101
Using the last loaded symbol settings. | 2022-02-17 17:49:39.101
Requested symbol settings for service code cqg. Request ID: 96. | 2022-02-17 17:49:39.101
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:39.101
Symbol settings received. Request ID: 96. | 2022-02-17 17:49:40.798
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:40.798 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:40.798
Using the last loaded symbol settings. | 2022-02-17 17:49:40.798
Requested symbol settings for service code cqg. Request ID: 97. | 2022-02-17 17:49:40.798
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:40.798
Symbol settings received. Request ID: 97. | 2022-02-17 17:49:42.633
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:42.633 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:42.633
Using the last loaded symbol settings. | 2022-02-17 17:49:42.633
Requested symbol settings for service code cqg. Request ID: 98. | 2022-02-17 17:49:42.633
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:42.633
Symbol settings received. Request ID: 98. | 2022-02-17 17:49:44.441
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:44.441 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:44.441
Using the last loaded symbol settings. | 2022-02-17 17:49:44.441
Requested symbol settings for service code cqg. Request ID: 99. | 2022-02-17 17:49:44.441
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:44.441
Symbol settings received. Request ID: 99. | 2022-02-17 17:49:46.137
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:46.138 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:46.138
Using the last loaded symbol settings. | 2022-02-17 17:49:46.138
Requested symbol settings for service code cqg. Request ID: 100. | 2022-02-17 17:49:46.138
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:46.138
Symbol settings received. Request ID: 100. | 2022-02-17 17:49:47.900
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:47.900 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:47.900
Using the last loaded symbol settings. | 2022-02-17 17:49:47.900
Requested symbol settings for service code cqg. Request ID: 101. | 2022-02-17 17:49:47.900
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:47.900
Symbol settings received. Request ID: 101. | 2022-02-17 17:49:49.576
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:49.577 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:49.577
Using the last loaded symbol settings. | 2022-02-17 17:49:49.577
Requested symbol settings for service code cqg. Request ID: 102. | 2022-02-17 17:49:49.577
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:49.577
Symbol settings received. Request ID: 102. | 2022-02-17 17:49:51.504
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:51.505 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:51.505
Using the last loaded symbol settings. | 2022-02-17 17:49:51.505
Requested symbol settings for service code cqg. Request ID: 103. | 2022-02-17 17:49:51.505
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:51.505
Symbol settings received. Request ID: 103. | 2022-02-17 17:49:53.254
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:53.254 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:53.254
Using the last loaded symbol settings. | 2022-02-17 17:49:53.254
Requested symbol settings for service code cqg. Request ID: 104. | 2022-02-17 17:49:53.254
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:53.254
Symbol settings received. Request ID: 104. | 2022-02-17 17:49:55.062
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:55.063 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:55.063
Using the last loaded symbol settings. | 2022-02-17 17:49:55.063
Requested symbol settings for service code cqg. Request ID: 105. | 2022-02-17 17:49:55.063
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:55.063
Symbol settings received. Request ID: 105. | 2022-02-17 17:49:56.838
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:56.838 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:56.838
Using the last loaded symbol settings. | 2022-02-17 17:49:56.838
Requested symbol settings for service code cqg. Request ID: 106. | 2022-02-17 17:49:56.838
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:56.838
Symbol settings received. Request ID: 106. | 2022-02-17 17:49:58.596
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:49:58.596 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:49:58.596
Using the last loaded symbol settings. | 2022-02-17 17:49:58.596
Requested symbol settings for service code cqg. Request ID: 107. | 2022-02-17 17:49:58.596
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:49:58.596
Symbol settings received. Request ID: 107. | 2022-02-17 17:50:00.553
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:00.553 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:00.553
Using the last loaded symbol settings. | 2022-02-17 17:50:00.553
Requested symbol settings for service code cqg. Request ID: 108. | 2022-02-17 17:50:00.553
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:00.553
Symbol settings received. Request ID: 108. | 2022-02-17 17:50:02.290
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:02.291 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:02.291
Using the last loaded symbol settings. | 2022-02-17 17:50:02.291
Requested symbol settings for service code cqg. Request ID: 109. | 2022-02-17 17:50:02.291
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:02.291
Symbol settings received. Request ID: 109. | 2022-02-17 17:50:04.038
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:04.038 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:04.038
Using the last loaded symbol settings. | 2022-02-17 17:50:04.038
Requested symbol settings for service code cqg. Request ID: 110. | 2022-02-17 17:50:04.038
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:04.038
Symbol settings received. Request ID: 110. | 2022-02-17 17:50:05.916
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:05.917 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:05.917
Using the last loaded symbol settings. | 2022-02-17 17:50:05.917
Requested symbol settings for service code cqg. Request ID: 111. | 2022-02-17 17:50:05.917
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:05.917
Symbol settings received. Request ID: 111. | 2022-02-17 17:50:07.588
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:07.588 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:07.588
Using the last loaded symbol settings. | 2022-02-17 17:50:07.588
Requested symbol settings for service code cqg. Request ID: 112. | 2022-02-17 17:50:07.588
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:07.588
CQG WebSocket socket (2) | Deleting network socket now after delay. | 2022-02-17 17:50:07.744
Symbol settings received. Request ID: 112. | 2022-02-17 17:50:09.525
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:09.525 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:09.525
Using the last loaded symbol settings. | 2022-02-17 17:50:09.525
Requested symbol settings for service code cqg. Request ID: 113. | 2022-02-17 17:50:09.525
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:09.525
Symbol settings received. Request ID: 113. | 2022-02-17 17:50:11.325
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:11.326 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:11.326
Using the last loaded symbol settings. | 2022-02-17 17:50:11.326
Requested symbol settings for service code cqg. Request ID: 114. | 2022-02-17 17:50:11.326
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:11.326
Symbol settings received. Request ID: 114. | 2022-02-17 17:50:13.094
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:13.095 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:13.095
Using the last loaded symbol settings. | 2022-02-17 17:50:13.095
Requested symbol settings for service code cqg. Request ID: 115. | 2022-02-17 17:50:13.095
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:13.095
Symbol settings received. Request ID: 115. | 2022-02-17 17:50:14.848
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:14.848 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:14.848
Using the last loaded symbol settings. | 2022-02-17 17:50:14.848
Requested symbol settings for service code cqg. Request ID: 116. | 2022-02-17 17:50:14.848
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:14.848
Symbol settings received. Request ID: 116. | 2022-02-17 17:50:16.664
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:16.664 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:16.664
Using the last loaded symbol settings. | 2022-02-17 17:50:16.664
Requested symbol settings for service code cqg. Request ID: 117. | 2022-02-17 17:50:16.664
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:16.664
Symbol settings received. Request ID: 117. | 2022-02-17 17:50:18.378
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:18.378 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:18.378
Using the last loaded symbol settings. | 2022-02-17 17:50:18.378
Requested symbol settings for service code cqg. Request ID: 118. | 2022-02-17 17:50:18.378
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:18.378
Symbol settings received. Request ID: 118. | 2022-02-17 17:50:20.134
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:20.135 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:20.135
Using the last loaded symbol settings. | 2022-02-17 17:50:20.135
Requested symbol settings for service code cqg. Request ID: 119. | 2022-02-17 17:50:20.135
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:20.135
Symbol settings received. Request ID: 119. | 2022-02-17 17:50:22.054
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:22.054 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:22.054
Using the last loaded symbol settings. | 2022-02-17 17:50:22.054
Requested symbol settings for service code cqg. Request ID: 120. | 2022-02-17 17:50:22.054
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:22.054
Symbol settings received. Request ID: 120. | 2022-02-17 17:50:23.868
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:23.868 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:23.868
Using the last loaded symbol settings. | 2022-02-17 17:50:23.868
Requested symbol settings for service code cqg. Request ID: 121. | 2022-02-17 17:50:23.868
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:23.868
Symbol settings received. Request ID: 121. | 2022-02-17 17:50:25.726
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:25.727 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:25.727
Using the last loaded symbol settings. | 2022-02-17 17:50:25.727
Requested symbol settings for service code cqg. Request ID: 122. | 2022-02-17 17:50:25.727
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:25.727
Symbol settings received. Request ID: 122. | 2022-02-17 17:50:27.497
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:27.498 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:27.498
Using the last loaded symbol settings. | 2022-02-17 17:50:27.498
Requested symbol settings for service code cqg. Request ID: 123. | 2022-02-17 17:50:27.498
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:27.498
Symbol settings received. Request ID: 123. | 2022-02-17 17:50:29.401
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:29.401 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:29.402
Using the last loaded symbol settings. | 2022-02-17 17:50:29.402
Requested symbol settings for service code cqg. Request ID: 124. | 2022-02-17 17:50:29.402
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:29.402
Symbol settings received. Request ID: 124. | 2022-02-17 17:50:31.236
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:31.237 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:31.237
Using the last loaded symbol settings. | 2022-02-17 17:50:31.237
Requested symbol settings for service code cqg. Request ID: 125. | 2022-02-17 17:50:31.237
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:31.237
Symbol settings received. Request ID: 125. | 2022-02-17 17:50:33.029
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:33.030 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:33.030
Using the last loaded symbol settings. | 2022-02-17 17:50:33.030
Requested symbol settings for service code cqg. Request ID: 126. | 2022-02-17 17:50:33.030
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:33.030
Symbol settings received. Request ID: 126. | 2022-02-17 17:50:34.812
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:34.812 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:34.812
Using the last loaded symbol settings. | 2022-02-17 17:50:34.812
Requested symbol settings for service code cqg. Request ID: 127. | 2022-02-17 17:50:34.812
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:34.812
Symbol settings received. Request ID: 127. | 2022-02-17 17:50:36.688
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:36.689 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:36.690
Using the last loaded symbol settings. | 2022-02-17 17:50:36.690
Requested symbol settings for service code cqg. Request ID: 128. | 2022-02-17 17:50:36.690
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:36.690
Symbol settings received. Request ID: 128. | 2022-02-17 17:50:38.492
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:38.492 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:38.492
Using the last loaded symbol settings. | 2022-02-17 17:50:38.492
Requested symbol settings for service code cqg. Request ID: 129. | 2022-02-17 17:50:38.493
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:38.493
Symbol settings received. Request ID: 129. | 2022-02-17 17:50:40.207
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:40.207 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:40.207
Using the last loaded symbol settings. | 2022-02-17 17:50:40.207
Requested symbol settings for service code cqg. Request ID: 130. | 2022-02-17 17:50:40.207
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:40.207
Symbol settings received. Request ID: 130. | 2022-02-17 17:50:41.896
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:41.896 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:41.896
Using the last loaded symbol settings. | 2022-02-17 17:50:41.896
Requested symbol settings for service code cqg. Request ID: 131. | 2022-02-17 17:50:41.896
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:41.896
Symbol settings received. Request ID: 131. | 2022-02-17 17:50:43.555
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:43.556 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:43.556
Using the last loaded symbol settings. | 2022-02-17 17:50:43.556
Requested symbol settings for service code cqg. Request ID: 132. | 2022-02-17 17:50:43.556
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:43.556
Symbol settings received. Request ID: 132. | 2022-02-17 17:50:45.273
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:45.274 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:45.274
Using the last loaded symbol settings. | 2022-02-17 17:50:45.274
Requested symbol settings for service code cqg. Request ID: 133. | 2022-02-17 17:50:45.274
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:45.274
Symbol settings received. Request ID: 133. | 2022-02-17 17:50:47.116
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:47.116 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:47.116
Using the last loaded symbol settings. | 2022-02-17 17:50:47.116
Requested symbol settings for service code cqg. Request ID: 134. | 2022-02-17 17:50:47.116
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:47.116
Symbol settings received. Request ID: 134. | 2022-02-17 17:50:48.919
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:48.919 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:48.919
Using the last loaded symbol settings. | 2022-02-17 17:50:48.919
Requested symbol settings for service code cqg. Request ID: 135. | 2022-02-17 17:50:48.919
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:48.919
Symbol settings received. Request ID: 135. | 2022-02-17 17:50:50.717
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:50.717 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:50.717
Using the last loaded symbol settings. | 2022-02-17 17:50:50.717
Requested symbol settings for service code cqg. Request ID: 136. | 2022-02-17 17:50:50.717
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:50.717
Symbol settings received. Request ID: 136. | 2022-02-17 17:50:52.436
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:52.437 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:52.437
Using the last loaded symbol settings. | 2022-02-17 17:50:52.437
Requested symbol settings for service code cqg. Request ID: 137. | 2022-02-17 17:50:52.437
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:52.437
Symbol settings received. Request ID: 137. | 2022-02-17 17:50:54.188
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:54.188 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:54.188
Using the last loaded symbol settings. | 2022-02-17 17:50:54.188
Requested symbol settings for service code cqg. Request ID: 138. | 2022-02-17 17:50:54.188
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:54.188
Symbol settings received. Request ID: 138. | 2022-02-17 17:50:56.043
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:56.043 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:56.043
Using the last loaded symbol settings. | 2022-02-17 17:50:56.043
Requested symbol settings for service code cqg. Request ID: 139. | 2022-02-17 17:50:56.043
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:56.043
Symbol settings received. Request ID: 139. | 2022-02-17 17:50:57.730
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:57.730 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:57.731
Using the last loaded symbol settings. | 2022-02-17 17:50:57.731
Requested symbol settings for service code cqg. Request ID: 140. | 2022-02-17 17:50:57.731
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:57.731
Symbol settings received. Request ID: 140. | 2022-02-17 17:50:59.426
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:50:59.426 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:50:59.426
Using the last loaded symbol settings. | 2022-02-17 17:50:59.426
Requested symbol settings for service code cqg. Request ID: 141. | 2022-02-17 17:50:59.426
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:50:59.426
Symbol settings received. Request ID: 141. | 2022-02-17 17:51:01.166
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:01.166 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:01.166
Using the last loaded symbol settings. | 2022-02-17 17:51:01.166
Requested symbol settings for service code cqg. Request ID: 142. | 2022-02-17 17:51:01.166
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:01.166
Symbol settings received. Request ID: 142. | 2022-02-17 17:51:03.084
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:03.084 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:03.084
Using the last loaded symbol settings. | 2022-02-17 17:51:03.084
Requested symbol settings for service code cqg. Request ID: 143. | 2022-02-17 17:51:03.084
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:03.084
Symbol settings received. Request ID: 143. | 2022-02-17 17:51:04.807
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:04.807 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:04.807
Using the last loaded symbol settings. | 2022-02-17 17:51:04.807
Requested symbol settings for service code cqg. Request ID: 144. | 2022-02-17 17:51:04.807
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:04.807
Symbol settings received. Request ID: 144. | 2022-02-17 17:51:06.525
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:06.525 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:06.525
Using the last loaded symbol settings. | 2022-02-17 17:51:06.525
Requested symbol settings for service code cqg. Request ID: 145. | 2022-02-17 17:51:06.525
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:06.525
Symbol settings received. Request ID: 145. | 2022-02-17 17:51:08.295
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:08.296 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:08.296
Using the last loaded symbol settings. | 2022-02-17 17:51:08.296
Requested symbol settings for service code cqg. Request ID: 146. | 2022-02-17 17:51:08.296
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:08.296
Symbol settings received. Request ID: 146. | 2022-02-17 17:51:10.043
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:10.043 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:10.043
Using the last loaded symbol settings. | 2022-02-17 17:51:10.043
Requested symbol settings for service code cqg. Request ID: 147. | 2022-02-17 17:51:10.043
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:10.043
Symbol settings received. Request ID: 147. | 2022-02-17 17:51:11.888
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:11.888 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:11.888
Using the last loaded symbol settings. | 2022-02-17 17:51:11.888
Requested symbol settings for service code cqg. Request ID: 148. | 2022-02-17 17:51:11.888
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:11.888
Symbol settings received. Request ID: 148. | 2022-02-17 17:51:13.630
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:13.630 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:13.631
Using the last loaded symbol settings. | 2022-02-17 17:51:13.631
Requested symbol settings for service code cqg. Request ID: 149. | 2022-02-17 17:51:13.631
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:13.631
Symbol settings received. Request ID: 149. | 2022-02-17 17:51:15.408
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:15.409 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:15.409
Using the last loaded symbol settings. | 2022-02-17 17:51:15.409
Requested symbol settings for service code cqg. Request ID: 150. | 2022-02-17 17:51:15.409
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:15.409
Symbol settings received. Request ID: 150. | 2022-02-17 17:51:17.094
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:17.095 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:17.095
Using the last loaded symbol settings. | 2022-02-17 17:51:17.095
Requested symbol settings for service code cqg. Request ID: 151. | 2022-02-17 17:51:17.095
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:17.095
Symbol settings received. Request ID: 151. | 2022-02-17 17:51:18.905
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:18.905 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:18.905
Using the last loaded symbol settings. | 2022-02-17 17:51:18.905
Requested symbol settings for service code cqg. Request ID: 152. | 2022-02-17 17:51:18.905
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:18.905
Symbol settings received. Request ID: 152. | 2022-02-17 17:51:20.670
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:20.670 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:20.670
Using the last loaded symbol settings. | 2022-02-17 17:51:20.670
Requested symbol settings for service code cqg. Request ID: 153. | 2022-02-17 17:51:20.670
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:20.670
Symbol settings received. Request ID: 153. | 2022-02-17 17:51:22.449
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:22.450 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:22.450
Using the last loaded symbol settings. | 2022-02-17 17:51:22.450
Requested symbol settings for service code cqg. Request ID: 154. | 2022-02-17 17:51:22.450
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:22.450
Symbol settings received. Request ID: 154. | 2022-02-17 17:51:24.181
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:24.182 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:24.182
Using the last loaded symbol settings. | 2022-02-17 17:51:24.182
Requested symbol settings for service code cqg. Request ID: 155. | 2022-02-17 17:51:24.182
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:24.182
Symbol settings received. Request ID: 155. | 2022-02-17 17:51:25.894
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:25.895 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:25.895
Using the last loaded symbol settings. | 2022-02-17 17:51:25.895
Requested symbol settings for service code cqg. Request ID: 156. | 2022-02-17 17:51:25.895
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:25.895
Symbol settings received. Request ID: 156. | 2022-02-17 17:51:27.620
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:27.621 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:27.621
Using the last loaded symbol settings. | 2022-02-17 17:51:27.621
Requested symbol settings for service code cqg. Request ID: 157. | 2022-02-17 17:51:27.621
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:27.621
Symbol settings received. Request ID: 157. | 2022-02-17 17:51:29.362
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:29.363 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:29.363
Using the last loaded symbol settings. | 2022-02-17 17:51:29.363
Requested symbol settings for service code cqg. Request ID: 158. | 2022-02-17 17:51:29.363
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:29.363
Symbol settings received. Request ID: 158. | 2022-02-17 17:51:31.104
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:31.104 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:31.104
Using the last loaded symbol settings. | 2022-02-17 17:51:31.104
Requested symbol settings for service code cqg. Request ID: 159. | 2022-02-17 17:51:31.104
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:31.104
Symbol settings received. Request ID: 159. | 2022-02-17 17:51:32.949
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:32.950 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:32.950
Using the last loaded symbol settings. | 2022-02-17 17:51:32.950
Requested symbol settings for service code cqg. Request ID: 160. | 2022-02-17 17:51:32.950
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:32.950
Symbol settings received. Request ID: 160. | 2022-02-17 17:51:34.681
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:34.681 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:34.681
Using the last loaded symbol settings. | 2022-02-17 17:51:34.681
Requested symbol settings for service code cqg. Request ID: 161. | 2022-02-17 17:51:34.681
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:34.681
Symbol settings received. Request ID: 161. | 2022-02-17 17:51:36.411
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:36.411 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:36.412
Using the last loaded symbol settings. | 2022-02-17 17:51:36.412
Requested symbol settings for service code cqg. Request ID: 162. | 2022-02-17 17:51:36.412
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:36.412
Symbol settings received. Request ID: 162. | 2022-02-17 17:51:38.184
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:38.184 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:38.184
Using the last loaded symbol settings. | 2022-02-17 17:51:38.184
Requested symbol settings for service code cqg. Request ID: 163. | 2022-02-17 17:51:38.185
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:38.185
Symbol settings received. Request ID: 163. | 2022-02-17 17:51:39.866
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:39.867 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:39.867
Using the last loaded symbol settings. | 2022-02-17 17:51:39.867
Requested symbol settings for service code cqg. Request ID: 164. | 2022-02-17 17:51:39.867
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:39.867
Symbol settings received. Request ID: 164. | 2022-02-17 17:51:41.661
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:41.662 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:41.662
Using the last loaded symbol settings. | 2022-02-17 17:51:41.662
Requested symbol settings for service code cqg. Request ID: 165. | 2022-02-17 17:51:41.662
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:41.662
Symbol settings received. Request ID: 165. | 2022-02-17 17:51:43.318
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:43.318 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:43.318
Using the last loaded symbol settings. | 2022-02-17 17:51:43.318
Requested symbol settings for service code cqg. Request ID: 166. | 2022-02-17 17:51:43.318
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:43.318
Symbol settings received. Request ID: 166. | 2022-02-17 17:51:45.128
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:45.128 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:45.128
Using the last loaded symbol settings. | 2022-02-17 17:51:45.128
Requested symbol settings for service code cqg. Request ID: 167. | 2022-02-17 17:51:45.128
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:45.128
Symbol settings received. Request ID: 167. | 2022-02-17 17:51:46.879
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:46.879 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:46.879
Using the last loaded symbol settings. | 2022-02-17 17:51:46.879
Requested symbol settings for service code cqg. Request ID: 168. | 2022-02-17 17:51:46.879
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:46.879
Symbol settings received. Request ID: 168. | 2022-02-17 17:51:48.618
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:48.618 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:48.618
Using the last loaded symbol settings. | 2022-02-17 17:51:48.618
Requested symbol settings for service code cqg. Request ID: 169. | 2022-02-17 17:51:48.618
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:48.618
Symbol settings received. Request ID: 169. | 2022-02-17 17:51:50.446
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:50.446 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:50.446
Using the last loaded symbol settings. | 2022-02-17 17:51:50.446
Requested symbol settings for service code cqg. Request ID: 170. | 2022-02-17 17:51:50.447
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:50.447
Symbol settings received. Request ID: 170. | 2022-02-17 17:51:52.236
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:52.237 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:52.237
Using the last loaded symbol settings. | 2022-02-17 17:51:52.237
Requested symbol settings for service code cqg. Request ID: 171. | 2022-02-17 17:51:52.237
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:52.237
Symbol settings received. Request ID: 171. | 2022-02-17 17:51:53.990
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:53.990 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:53.990
Using the last loaded symbol settings. | 2022-02-17 17:51:53.990
Requested symbol settings for service code cqg. Request ID: 172. | 2022-02-17 17:51:53.990
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:53.990
Symbol settings received. Request ID: 172. | 2022-02-17 17:51:55.775
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:55.775 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:55.775
Using the last loaded symbol settings. | 2022-02-17 17:51:55.775
Requested symbol settings for service code cqg. Request ID: 173. | 2022-02-17 17:51:55.775
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:55.775
Symbol settings received. Request ID: 173. | 2022-02-17 17:51:57.560
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:57.560 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:57.560
Using the last loaded symbol settings. | 2022-02-17 17:51:57.560
Requested symbol settings for service code cqg. Request ID: 174. | 2022-02-17 17:51:57.560
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:57.560
Symbol settings received. Request ID: 174. | 2022-02-17 17:51:59.423
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:51:59.424 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:51:59.424
Using the last loaded symbol settings. | 2022-02-17 17:51:59.424
Requested symbol settings for service code cqg. Request ID: 175. | 2022-02-17 17:51:59.424
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:51:59.424
Symbol settings received. Request ID: 175. | 2022-02-17 17:52:01.263
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:01.263 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:01.263
Using the last loaded symbol settings. | 2022-02-17 17:52:01.263
Requested symbol settings for service code cqg. Request ID: 176. | 2022-02-17 17:52:01.263
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:01.263
Symbol settings received. Request ID: 176. | 2022-02-17 17:52:03.232
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:03.233 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:03.233
Using the last loaded symbol settings. | 2022-02-17 17:52:03.233
Requested symbol settings for service code cqg. Request ID: 177. | 2022-02-17 17:52:03.233
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:03.233
Symbol settings received. Request ID: 177. | 2022-02-17 17:52:04.985
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:04.985 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:04.985
Using the last loaded symbol settings. | 2022-02-17 17:52:04.985
Requested symbol settings for service code cqg. Request ID: 178. | 2022-02-17 17:52:04.985
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:04.985
Symbol settings received. Request ID: 178. | 2022-02-17 17:52:06.749
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:06.749 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:06.749
Using the last loaded symbol settings. | 2022-02-17 17:52:06.749
Requested symbol settings for service code cqg. Request ID: 179. | 2022-02-17 17:52:06.749
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:06.749
Symbol settings received. Request ID: 179. | 2022-02-17 17:52:08.438
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:08.438 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:08.438
Using the last loaded symbol settings. | 2022-02-17 17:52:08.438
Requested symbol settings for service code cqg. Request ID: 180. | 2022-02-17 17:52:08.438
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:08.438
Symbol settings received. Request ID: 180. | 2022-02-17 17:52:10.201
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:10.202 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:10.202
Using the last loaded symbol settings. | 2022-02-17 17:52:10.202
Requested symbol settings for service code cqg. Request ID: 181. | 2022-02-17 17:52:10.202
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:10.202
Symbol settings received. Request ID: 181. | 2022-02-17 17:52:12.070
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:12.070 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:12.070
Using the last loaded symbol settings. | 2022-02-17 17:52:12.070
Requested symbol settings for service code cqg. Request ID: 182. | 2022-02-17 17:52:12.070
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:12.070
Symbol settings received. Request ID: 182. | 2022-02-17 17:52:13.841
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:13.842 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:13.842
Using the last loaded symbol settings. | 2022-02-17 17:52:13.842
Requested symbol settings for service code cqg. Request ID: 183. | 2022-02-17 17:52:13.842
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:13.842
Symbol settings received. Request ID: 183. | 2022-02-17 17:52:15.659
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:15.659 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:15.659
Using the last loaded symbol settings. | 2022-02-17 17:52:15.659
Requested symbol settings for service code cqg. Request ID: 184. | 2022-02-17 17:52:15.659
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:15.659
Symbol settings received. Request ID: 184. | 2022-02-17 17:52:17.390
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:17.390 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:17.390
Using the last loaded symbol settings. | 2022-02-17 17:52:17.390
Requested symbol settings for service code cqg. Request ID: 185. | 2022-02-17 17:52:17.390
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:17.390
Symbol settings received. Request ID: 185. | 2022-02-17 17:52:19.335
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:19.335 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:19.335
Using the last loaded symbol settings. | 2022-02-17 17:52:19.335
Requested symbol settings for service code cqg. Request ID: 186. | 2022-02-17 17:52:19.335
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:19.335
Symbol settings received. Request ID: 186. | 2022-02-17 17:52:21.087
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:21.088 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:21.088
Using the last loaded symbol settings. | 2022-02-17 17:52:21.088
Requested symbol settings for service code cqg. Request ID: 187. | 2022-02-17 17:52:21.088
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:21.088
Symbol settings received. Request ID: 187. | 2022-02-17 17:52:22.931
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:22.932 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:22.932
Using the last loaded symbol settings. | 2022-02-17 17:52:22.932
Requested symbol settings for service code cqg. Request ID: 188. | 2022-02-17 17:52:22.932
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:22.932
Symbol settings received. Request ID: 188. | 2022-02-17 17:52:24.659
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:24.660 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:24.660
Using the last loaded symbol settings. | 2022-02-17 17:52:24.660
Requested symbol settings for service code cqg. Request ID: 189. | 2022-02-17 17:52:24.660
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:24.660
Symbol settings received. Request ID: 189. | 2022-02-17 17:52:26.384
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:26.385 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:26.385
Using the last loaded symbol settings. | 2022-02-17 17:52:26.385
Requested symbol settings for service code cqg. Request ID: 190. | 2022-02-17 17:52:26.386
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:26.386
Symbol settings received. Request ID: 190. | 2022-02-17 17:52:28.073
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:28.074 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:28.074
Using the last loaded symbol settings. | 2022-02-17 17:52:28.074
Requested symbol settings for service code cqg. Request ID: 191. | 2022-02-17 17:52:28.074
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:28.074
Symbol settings received. Request ID: 191. | 2022-02-17 17:52:29.917
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:29.918 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:29.918
Using the last loaded symbol settings. | 2022-02-17 17:52:29.918
Requested symbol settings for service code cqg. Request ID: 192. | 2022-02-17 17:52:29.918
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:29.918
Symbol settings received. Request ID: 192. | 2022-02-17 17:52:31.719
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:31.720 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:31.720
Using the last loaded symbol settings. | 2022-02-17 17:52:31.720
Requested symbol settings for service code cqg. Request ID: 193. | 2022-02-17 17:52:31.720
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:31.720
Symbol settings received. Request ID: 193. | 2022-02-17 17:52:33.456
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:33.457 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:33.457
Using the last loaded symbol settings. | 2022-02-17 17:52:33.457
Requested symbol settings for service code cqg. Request ID: 194. | 2022-02-17 17:52:33.457
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:33.457
Symbol settings received. Request ID: 194. | 2022-02-17 17:52:35.133
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:35.133 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:35.133
Using the last loaded symbol settings. | 2022-02-17 17:52:35.133
Requested symbol settings for service code cqg. Request ID: 195. | 2022-02-17 17:52:35.133
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:35.133
Symbol settings received. Request ID: 195. | 2022-02-17 17:52:36.929
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:36.930 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:36.930
Using the last loaded symbol settings. | 2022-02-17 17:52:36.930
Requested symbol settings for service code cqg. Request ID: 196. | 2022-02-17 17:52:36.930
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:36.930
Symbol settings received. Request ID: 196. | 2022-02-17 17:52:38.796
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:38.797 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:38.797
Using the last loaded symbol settings. | 2022-02-17 17:52:38.797
Requested symbol settings for service code cqg. Request ID: 197. | 2022-02-17 17:52:38.797
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:38.797
Symbol settings received. Request ID: 197. | 2022-02-17 17:52:40.550
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:40.550 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:40.550
Using the last loaded symbol settings. | 2022-02-17 17:52:40.550
Requested symbol settings for service code cqg. Request ID: 198. | 2022-02-17 17:52:40.550
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:40.550
Symbol settings received. Request ID: 198. | 2022-02-17 17:52:42.301
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:42.301 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:42.301
Using the last loaded symbol settings. | 2022-02-17 17:52:42.301
Requested symbol settings for service code cqg. Request ID: 199. | 2022-02-17 17:52:42.301
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:42.301
Symbol settings received. Request ID: 199. | 2022-02-17 17:52:44.075
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:44.075 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:44.075
Using the last loaded symbol settings. | 2022-02-17 17:52:44.075
Requested symbol settings for service code cqg. Request ID: 200. | 2022-02-17 17:52:44.075
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:44.075
Symbol settings received. Request ID: 200. | 2022-02-17 17:52:45.885
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:45.886 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:45.886
Using the last loaded symbol settings. | 2022-02-17 17:52:45.886
Requested symbol settings for service code cqg. Request ID: 201. | 2022-02-17 17:52:45.886
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:45.886
Symbol settings received. Request ID: 201. | 2022-02-17 17:52:47.803
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:47.803 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:47.803
Using the last loaded symbol settings. | 2022-02-17 17:52:47.803
Requested symbol settings for service code cqg. Request ID: 202. | 2022-02-17 17:52:47.803
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:47.803
Symbol settings received. Request ID: 202. | 2022-02-17 17:52:49.611
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:49.612 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:49.612
Using the last loaded symbol settings. | 2022-02-17 17:52:49.612
Requested symbol settings for service code cqg. Request ID: 203. | 2022-02-17 17:52:49.612
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:49.612
Symbol settings received. Request ID: 203. | 2022-02-17 17:52:51.273
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:51.273 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:51.274
Using the last loaded symbol settings. | 2022-02-17 17:52:51.274
Requested symbol settings for service code cqg. Request ID: 204. | 2022-02-17 17:52:51.274
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:51.274
Symbol settings received. Request ID: 204. | 2022-02-17 17:52:52.932
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:52.933 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:52.933
Using the last loaded symbol settings. | 2022-02-17 17:52:52.933
Requested symbol settings for service code cqg. Request ID: 205. | 2022-02-17 17:52:52.933
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:52.933
Symbol settings received. Request ID: 205. | 2022-02-17 17:52:54.717
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:54.717 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:54.717
Using the last loaded symbol settings. | 2022-02-17 17:52:54.717
Requested symbol settings for service code cqg. Request ID: 206. | 2022-02-17 17:52:54.717
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:54.717
Symbol settings received. Request ID: 206. | 2022-02-17 17:52:56.525
Error saving the service symbol settings to "E:\GTC\SierraChart\SymbolSettings\SymbolSettings.cqg.xml". Failed to open the file. Windows error code 1392: Le fichier ou le répertoire est endommagé et illisible. | 2022-02-17 17:52:56.526 *
Symbol settings could not be loaded because there are no applicable files to load. | 2022-02-17 17:52:56.526
Using the last loaded symbol settings. | 2022-02-17 17:52:56.526
Requested symbol settings for service code cqg. Request ID: 207. | 2022-02-17 17:52:56.526
Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2022-02-17 17:52:56.526
[2022-02-17 18:02:33]
John - SC Support - Posts: 47889
You are getting the following error:
You are having a problem with your drive that has Sierra Chart on it. You will want to either try to repair the drive or get a new one.
Refer to the following for files you will want to try and recover and move to a new installation, if you can:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
