Date/Time: Thu, 06 Mar 2025 21:55:05 +0000
Several things...
View Count: 536
[2022-02-17 15:13:16] |
User368639 - Posts: 45 |
1. I left AMP, primarily to get access to Teton and to get better broker customer service. They are getting worse not better. 2. I trade from Italy. Latency has been a problem for years. With Sierra, latency is no longer a problem. With Teton, even less. 3. I chose EdgeClear because I worked with Max previously; superb customer service so far. Please give them your full support. 4. The programmer Onn is first rate. Needed an indicator translated from TOS. Done in 3 days. Excellent price. Zero hassle. 5. Watched your webinar with Edge. Excellent plans for the future. Thank you. 6. Being a new user, I messed with many settings, re Hung Order post, etc.. This morning, I uninstalled and reinstalled SC to get a complete clean start. All seems good now. |
[2022-02-17 15:17:58] |
2. That is good to know. Really interesting. So previously you were using CQG? 3. Great 6. Ok. But really reinstallation is something that is not recommended/necessary and if you just let us know what specific problem you have, we will help you with it and get it resolved without having to go through that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-17 15:18:09
