Date/Time: Thu, 06 Mar 2025 21:59:39 +0000
ESH22-CME
View Count: 494
[2022-02-17 15:13:00]
noodle - Posts: 2
Hi there - I can't seem to load this charting. I keep getting an error saying Symbol Settings not found for current service?
Thank you
[2022-02-17 16:57:22]
John - SC Support - Posts: 38464
Our servers show that you are connected to Interactive Brokers. That is not the correct symbol for Interactive Brokers.
Make sure your chartbooks are open and then select Edit >> Translate Symbols to Current Service and the symbols will be changed to match what is needed for Interactive Brokers. Refer to the information here for this command:
Edit Menu: Edit >> Translate Symbols To Current Service
[2022-02-17 18:02:54]
noodle - Posts: 2
Thank you
