Date/Time: Thu, 06 Mar 2025 22:31:26 +0000
“Rithmic Paper Trading
View Count: 760
[2022-02-17 15:09:07] |
User661060 - Posts: 1 |
Dear, thank you for the help, I think I did it already but it gave me the next error: Waiting the connection (in yellow) error: Connection error message from service; Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe | Date-Time:2022-02-16 22:26:02 I dont know what to do. Could you please help me saying what I can do? Thanks in advance Damaso |
[2022-02-17 16:29:07] |
John - SC Support - Posts: 38467 |
You are not connecting to the correct Rithmic connection. Follow the instructions at the following link to connect to Rithmic using the current connectivity. Note that the service selection will be Rithmic Direct - DTC. Rithmic Trading Platform Service: Setup Instructions Also, make sure you upgrade to the current release by following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
