Date/Time: Fri, 07 Mar 2025 01:25:51 +0000
Eurex Denali data not updating on QuoteBoard
View Count: 536
[2022-02-17 10:21:14] |
Marmany - Posts: 308 |
Not receiving any data for Eurex symbols in QuoteBoards today. However Charts are updating correctly. Tried disconnect / reconnect but situation unchanged. Please advise. |
[2022-02-17 13:03:00] |
Make sure the symbols are correct and set to the current contracts. Also translate them to the current service: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-17 13:03:24
[2022-02-17 16:56:41] |
Quoteboards are linked to Charts. Clicking on symbol in Quoteboard loads Chart with data which is updating correctly, however no data for the symbol appears on the Quoteboard. Quotboards were updating for Eurex symbols yesterday and I have changed nothing since then. I also have a spreadsheet which is not receiving Eurex data today. CME data is loading correctly in Quoteboards and spreadsheet. SC V2355 Please let me know if more details required to resolve the situation. |
[2022-02-18 01:12:14] |
Provide a screenshot of the quote board. Instructions to attach: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-18 17:04:18] |
Data loading correctly into QuoteBoards and spreadsheet today. Yesterday the rows for Eurex symbols appeared as if Sierra was opened on a Sat or Sun. None of my settings were changed, though the CPU was re-booted. If situation occurs again I will send screen shot as requested. |
[2022-02-18 22:21:27] |
Something like this really does not make sense. The Quote Board functionality is very simple and straightforward and there should not be any problems with quote lines updating if the symbols are correct and there is data available from the data feed.
