Date/Time: Fri, 18 Sep 2026 20:01:06 +0000
ES price on charts have moved the decimal. 4461.25 is now 446125.00
View Count: 841
| [2022-02-17 00:20:54] |
| User547290 - Posts: 86 |
I open a new chart and this is what I get. I choose the symbol and it changes it to (other) with the same symbol. Seems to be only happening in the H contracts. I have reloaded Sierra chart. This is from a new chartbook. My other charts ( older) are not effected. If I copy an old chart from a chartbook that has the correct info it is changed and I get the issue. If I just copy chart from the same chartbook I get the same issue. On top of this issue the DOM is now blank except for current price. I just had to update my data feed from TOPSTEP and soon after this is what I get. My data feed is a paid feed through Denali from you. What the $%^&@* is going on!! |
| [2022-02-17 02:31:24] |
Understand, this is a problem which was caused by you creating new symbol settings for the ES symbol. This is very clear from this screenshot: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=61496 Notice the ES symbol in the "Other" category. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Disable the use of Custom Symbol Settings Values. Very important. And then follow the instructions here: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-17 02:32:02
