Date/Time: Thu, 06 Mar 2025 21:59:03 +0000
Limiting Timeframe to current day for Market Depth Historical Graph
View Count: 663
[2022-02-16 22:39:59] |
Alex Q - Posts: 109 |
Hey guys. My question pertains to the study "Market Depth Historical Graph. I am using it with filters set to only send signals for orders over a specific size. It is working quite well, however it uses a lot of processing power, causing a bit of a lag, and loading the charts takes considerably longer when this study is on. My question is this: Is there a way to use the Market Depth Historical Graph study on ONLY the current trading day. There is no need for me to see what has happened on prior days. I am looking to be shown where large resting limit orders are for the current session only. Thank you in advance. |
[2022-02-17 03:57:20] |
Yes. It is this Chart Setting: Chart Settings: Maximum Market Depth Data Days to Load (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-17 06:05:11] |
Amazing. You guys are the best, and it's not even close.
