Date/Time: Thu, 06 Mar 2025 22:21:55 +0000
CBOT data
View Count: 482
[2022-02-16 15:14:55] |
User427880 - Posts: 8 |
I'm interested on trade in E micro DOW Futures (MYM) but I have no Data when I open the chart. I guess this is due to the package I currently have so I want to know what I have to do to fix it and he price as well. My broker is AMP futures. thank you |
[2022-02-16 16:27:23] |
First update Sierra Chart to the current version: Software Download: Fast Update And then: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
