Date/Time: Thu, 06 Mar 2025 22:15:07 +0000
chart not connecting
View Count: 432
[2022-02-16 15:11:03] |
User229460 - Posts: 24 |
chart isn't loading
[2022-02-16 15:25:07] |
Well we can try to help you with this, but we see you are a Transact user. And the best thing to do now, is to move to our new Teton order routing service which is replacing Transact. Refer to: *Important* Priority Message to Transact Users We can have someone call you to discuss this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-16 15:25:34
