Date/Time: Thu, 06 Mar 2025 22:07:29 +0000
vertical centering of date/time change
View Count: 509
[2022-02-16 12:20:08]
User138457 - Posts: 38
I am using "constant range" for the y axis and
having the following issue. When I jump to a different date/time (crtl+alt+G),
the vertical scale stays where it was. Is there a way to recenter vertically
on the price at that point where I jumped to?
Preferably sth. manual, like a shortcut, not "automatic on change of date/time"
[2022-02-16 16:40:44]
John - SC Support - Posts: 38464
You just need to "reset" the scales after you do the jump. Refer to the following:
Chart Scale and Scale Adjusting: Resetting the Scale
