Date/Time: Thu, 06 Mar 2025 22:31:31 +0000
Chart Dom Combine Increment in Ticks
View Count: 580
[2022-02-16 11:18:58] |
Sargon Petros - Posts: 57 |
Hi, I'm using the Combine Increment in Ticks feature on a chart, but for some reason when I do this, it is consolidating but only showing the Bid column. The same occurs when I use the feature on the dom itself. Am I doing something wrong? Thank you :) |
[2022-02-16 11:32:20] |
Update Sierra Chart to the current version following these instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-16 11:32:25
