Date/Time: Thu, 06 Mar 2025 22:15:00 +0000
Time and Sales Volume
View Count: 787
[2022-02-16 09:27:58] |
User135370 - Posts: 162 |
Hi Trying to get the Recent traded Volume to display on chart The Time and Sales Volume study says it shows the Bid Volume and Ask Volume from Time and Sales All it shows it one and zero depending on which beside of the spread being traded but no volume, I have attached a screen shot. What I am trying to achieve is having the Bid & Ask volume that is going through display on my chart without having to look across at the ladder. Am I using the right study? If I am what am I doing wrong? |
[2022-02-16 09:36:06] |
There is not any support for what you want.: Trying to get the Recent traded Volume to display on chart
Other than using the Chart DOM market data columns: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-16 10:52:40] |
Just curious then what is the Time and Sales Volume? Why does that only return 1's and 0's as per the image I attached
[2022-02-16 11:34:24] |
We cannot verify, what you have highlighted is even making reference to. Or verify the data.
