Date/Time: Thu, 06 Mar 2025 22:01:51 +0000
Open trading DOM for Chart Greyed out
View Count: 481
[2022-02-15 21:33:01] |
Ramanjit Saini - Posts: 3 |
Open trading DOM for Chart Greyed out Regards, RJ +1 346 244 8077 |
[2022-02-16 15:34:00] |
John - SC Support - Posts: 38464 |
You must not have a chart active at that time. For instance, if you have a Spreadsheet active when you select the File menu, you will not be able to select that option, since there is no specific chart selected.
