Date/Time: Fri, 07 Mar 2025 00:53:15 +0000
Access on another PC
View Count: 716
[2022-02-15 17:50:06] |
User657945 - Posts: 226 |
Hi I would like to know if is it possible to have access from a different PC that is on the house of my partner where I stay some days during the week, without to pay double contracts to you. Or in case the response it's negative which are the data available on the mobile version and the hardware requirements of the mobile phone i.e. Android Samsung phone. Specifically I use number bars/volume strategies so I need to see my charts. Thx |
[2022-02-15 18:20:17] |
John - SC Support - Posts: 38467 |
You can have Sierra Chart installed as many times in as many places as you desire. There are then 2 requirements that you need to be aware of. 1) You can only have 3 different computers running Sierra Chart at the same time. 2) You can only have 1 computer accessing the Denali data at a time. If a second computer tries to access the data, when another computer is already connected, then you will not be able to get the real-time data. You can increase this to two computers at the same time by paying for the exchange fee a second time. Refer to the following: Denali Exchange Data Feed: Connections As long as you are only using one system or the other at any given time, then you would not need to make any changes. But we just want you to be aware that if you forget to disconnect one computer and you are on the other, we do not have a way to force a disconnect from the first computer - you would have to get onto that computer in order to close Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-18 14:00:33] |
Thx John
