Date/Time: Fri, 07 Mar 2025 00:53:40 +0000
Locating dll file of studies
View Count: 768
[2022-02-13 22:05:10] |
User177329 - Posts: 35 |
Hi, does anyone know how can we locate the dll file of a studie that we'll be using on sierra?
[2022-02-14 00:14:09] |
1+1=10 - Posts: 270 |
If you're talking about a dll file for a study you're already using within SC you can follow the following process: 1. Open File Explorer. 2. Click on the SierraChart folder. 3. At the top right of explorer the search bar should say "Search within SierraChart". 4. Type in .dll in the searchbar (and hit enter). |
[2022-02-18 16:31:53] |
ForgivingComputers.com - Posts: 1021 |
The DLLs for studies need to be in the Data Files Folder which is usually c:\sierrachart\Data.
Date Time Of Last Edit: 2022-02-18 16:33:31
